Increasing Courant Number OpenFoam
Old   May 26, 2020, 17:07
Default Increasing Courant Number OpenFoam
Can Unsal
Battousai07 is on a distinguished road
Hi. I am working on a nonuniform, curved vessel. I need to solve the case in laminar transient which i've used pimpleFoam and icoFoam so far. The Courant number continiues to increase. I have tried adjustable time step and defined maxCo as 5 so far. This satisfies the condition but time step continiues to decrease very low values to make the condition satisfied. My mesh is OK in terms of skewness and orthogonatily. What can cause this problem?
Battousai07 is offline   Reply With Quote
Old   May 27, 2020, 05:34
geth03 is on a distinguished road
does the solver crash or does it run really slow with high CFL number?
geth03 is offline   Reply With Quote
Old   May 27, 2020, 07:33
Can Unsal
Runs with high CFL number. First it was crashing but i have managed to prevent that by introducing nonOrthogonal correctors and nCorrectors
Old   May 28, 2020, 04:03
can you output the courant number for your domain and analyze it with paraview? there is a function for that, which you need to write in controlDict.
you can then see where your CFL number is relatively high.
also execute checkMesh and check if a new directory is created in polyMesh-directory. if your mesh is broken somewhere the directory will be created.
you can then create vtk-files and open it with paraview, so your problematic areas will be highlighted.
Old   May 28, 2020, 18:28
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- Could you please execute `checkMesh -allGeometry -allTopology` and inspect the output (or share it here)?
- I think more info is needed to carry out further inspections. Could you please properly elaborate the simulation settings?
HPE is offline   Reply With Quote
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
