rotating pressure inlet static mesh simpleFOAM
Old   May 26, 2020, 16:23
Question rotating pressure inlet static mesh simpleFOAM
Christophe
cduchat is on a distinguished road
Hi all,
I am fairly new to openFOAM and having difficulties with a simulation: the domain is mostly cylindrical surrounding a cutout (defining channels like a volute and a couple pitot tubes), the outer boundaries of the domain are rotating walls ("walls-rotating") while the cutout is static walls ("walls-static"), the mesh is a single zone so I cannot really use a multiple reference frame approach. Linked to the static cutout and channels are two static outlets ("outlet" and "outlet-pitots"), while at the bottom of the domain and toward the outer diameter is a circular band where I want a rotating pressure inlet ("inlet") where the pressure controls the inflow but whatever enters does so at a specific rotation speed.
I am using BlueCFD-core 2017-2 (based on openFOAM v5), the simpleFOAM solver (steady-state simulation), and getting the following error:
--> FOAM FATAL IO ERROR:
keyword value is undefined in dictionary "C:/Users/Chris/Desktop/SVR-GTI/0/U.boundaryField.inlet"
file: C:/Users/Chris/Desktop/SVR-GTI/0/U.boundaryField.inlet from line 32 to line 34.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 566.
FOAM exiting
Here are the corresponding lines in the 0/U file:
30 inlet
31 {
32 type rotatingPressureInletOutletVelocity;
33 tangentialVelocity uniform (0.0 0.0 0.0);
34 omega constant 297.72;
35 }
And the pressure condition in the 0/p file:
inlet
type totalPressure;
p0 uniform 631.1;
gamma 0;
I also tried a different 0/U inlet condition that allowed to run but resulted in no inlet flow despite the pressure condition (instead the simulation seemed to treat "inlet" like a rotating wall and my fluids were entering the domain through "outlet-pitots" and exiting through "outlet"):
inlet
type cylindricalInletVelocity;
value uniform (0.0 0.0 0.0);
origin (0.0 0.0 0.0);
axialVelocity constant 0.0;
radialVelocity constant 0.0;
axis (0.0 0.0 1.0);
rpm constant 2843.0;
What am I missing/doing wrong?
cduchat is offline   Reply With Quote
Old   May 26, 2020, 16:44
Thumbs up Add a value field inside the boundary definition
Carlos Rubio Abujas
crubio.abujas is on a distinguished road
The crucial part of the error message if here.
You need to define a field "value" on the definition. Sometimes this value is never used, but it expected it, probably for inheritance from other fields where this field is in usage. The safe approach is to always define it, if the type don't need a value it just ignore this value and do its thing.
Try adding something like this:
 inlet
    value  uniform(0 0 0);
It is a good skill to interpret the information on the error messages. It can be a little intimated at first but you get use to it. Next time you see a "keyword XXX is undefined in dictionary YYY" you'll know where to look.
Hope it helps!
crubio.abujas is offline   Reply With Quote
Old   May 26, 2020, 17:00
Smile Thanks... new error messeage... maybe solved.
Christophe
Thanks a lot Carlos, I had looked into the source files and they were not calling for a "value" field, that's what threw me off.
I added the value field and it helped but I got another error message:
Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 34 the doubleScalar 297.72
file: C:/Users/Chris/Desktop/SVR-GTI/0/U.boundaryField.inlet.omega at line 34.
From function Foam::Istream& Foam::Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.T.C at line 92.
FOAM exiting
I gathered the "omega" was not expecting a scalar rotation speed, but rather a vector... I gave a try to "uniform (0 0 297.72)" and it seems to work (simulation running, we'll see if it does what I want it to).
Old   May 26, 2020, 17:15
Default Solved.
Christophe
I had to add a negative sign to my omega as it was spinning the wrong way, but otherwise it appears to be running just as intended.
Thanks again Carlos.
Old   May 27, 2020, 03:30
Default You're welcome
Carlos Rubio Abujas
Glad to know it helped you!
Good luck and happy foaming
Axial flow fan incorrect pressure rise yambanshee OpenFOAM Running, Solving & CFD 2 June 25, 2020 15:05
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Assign static pressure at inlet Tanjina FLUENT 0 November 3, 2013 12:34
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 15:57
