cyclicAMI does not work with every xxxFoam
Old   May 26, 2020, 13:42
Default cyclicAMI does not work with every xxxFoam
niewiemnic
spalartallmaras is on a distinguished road
I generated mesh with cfMesh+ and created cyclicAMI with createPatch.
and with this mesh if I set patchs no cyclicAMI but only wall, simulation works well.
After for example simpleFoam with cyclicAMI I get this messages,
SIMPLE: no convergence criteria found. Calculations will run for 1000 steps.
Reading field p
AMI: Creating addressing and weights between 167103 source faces and 170738 target faces
AMI: Patch source sum(weights) min:0.640991353 max:1.05538425 average:0.999995117
AMI: Patch target sum(weights) min:0 max:1.05267768 average:0.999967247
Reading field U
and
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0142960775, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0232782651, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0375231129, No Iterations 1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib64/libc.so.6
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4  ? at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#6  ? at simpleFoam.C:?
#7  ? at ??:?
#8  __libc_start_main in /lib64/libc.so.6
#9  ? at ??:?
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
Does anybody have an similar experience?
spalartallmaras is offline   Reply With Quote
Getting started with CyclicAMI Algebraist OpenFOAM 4 February 11, 2019 02:39
Non-physical pressure at cyclicAMI patches MNoCeZ OpenFOAM Running, Solving & CFD 0 September 20, 2017 18:35
CyclicAMI Boundary Condition CUBoulderPhDStudent OpenFOAM Running, Solving & CFD 0 May 21, 2014 19:34
Do all CFD analysts have to do some hands-on work except PhDs? e13drd Main CFD Forum 2 March 17, 2014 15:56
cyclicAMI and interDyMFoam for periodic box kwardle OpenFOAM 1 March 11, 2014 14:40
