May 25, 2020, 06:19 |
Unwanted Flow Direction
Rep Power: 8 |
I am running a dyson bladeless fan simulation using the simpleFoam solver with k-omega turbulence modelling. The computational domain is a (2m x 1.64m x 0.5m) box with top, bot, left, right, and back using zeroGradient boundary condition, while the front uses symmetry boundary condition. The inlet is located at 1/3 of the geometry length. You can see the sketch of this settings in the attached compDomainHalf1.pdf. After running the simulation for t = 1000s, the result shows flow coming out from the bottom region of the computational domain, disrupting the flow generated from the geometry, as seen in figure dyson60.pdf. You can also find the 0 file attached as zip. I expect the flow to have vorticity in the middle of the geometry.I am thankful for the help. Mr.Hz |
May 26, 2020, 14:36 |
Rep Power: 8 |
I dont fully understand the problem. The flow will always follow the pressure gradient. Depending on where you set which boundary conditions you impact your solution. But for me its not clear which BC are applied at which patch.
Maybe you can add a sketch to clarify things. Kind regards, shock77 |
May 27, 2020, 16:35 |
#3 | |
Rep Power: 8 |
Kind regards, Mr.Hz |
May 27, 2020, 18:46 |
Rep Power: 8 |
I have seen your attachments, but I cant see all the BCs. Or is everything zeroGradient?
Your 0 folder says, that you have definied a outlet with a fixed pressure and a inlet with a fixed velocity. This is typical for subsonic cases. But in your image it looks like everything is zeroGradient. Also the image with the vectors makes it hard to understand what you mean and what the real issue is. An image with the patch names and the BCs for atleast U and p would be helpful for me to understand the problem correctly. Kind regards, shock77 |
June 2, 2020, 15:29 |
Rep Power: 8 |
Update on the simulation, I have manage to "fix" the unwanted flow direction by changing the internal field in the 0/U into (-1 0 0). What it does is, it forces the flow direction into what I perceive to be the correct flow direction. You can see the simulation result in the attached figure.
simplefoam |
Flow being directed to one direction | rahulksoni | OpenFOAM Running, Solving & CFD | 0 | March 5, 2019 02:13 |
Question with flow direction | johnlui0302 | CFX | 1 | November 9, 2015 12:12 |
confusion in specifying domain flow direction and results | ashwani.thakur | CFX | 4 | February 28, 2015 07:45 |
High No Iterations in Secondary Flow Direction | camoesas | OpenFOAM Running, Solving & CFD | 0 | July 9, 2014 05:11 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 06:44 |
