Boundary Condition of Periodic Boundary Flow
Old   May 24, 2020, 11:59
Default Boundary Condition of Periodic Boundary Flow
Sereff
Sereff is on a distinguished road
Hi everyone,
Just a quick and easy check, If I were to run a periodic boundary flow simluation, I should implement the following bounary conditions:
Inlet
> velocity: cyclic; > pressure: cyclic; > nut: cyclic;
outlet
ground(wall)
for y+ < 5
> velocity: noSlip; > pressure: zeroGradient; > nut: zeroGradient;
for y+ > 30
> velocity: noSlip; > pressure: zeroGradient; > nut: nutUWallFunction;
upperAtm
> velocity: zeroGradient; > pressure: zeroGradient; > nut: zeroGradient;
sideAtm
Am I correct? With the BCs above I am not able to get the simulation to match the DNS data, by a bit margin. Any advise? Much appreciated
Kind regards,
Sereff is offline   Reply With Quote
Old   May 24, 2020, 12:13
Ardalan
Ardali is on a distinguished road
Is it a channel flow or free surface channel flow?
In general yes. It depends very much on your resolution.
I assume you talk about channel flow so check available tutotrail in OFm channel395.
Ardali is offline   Reply With Quote
Old   May 24, 2020, 12:57
Sereff
Hi Ardali,
Thank you for your reply. That was the case I based on and I validated against. I think the problem might lies in the fvScheme, where I implemented
> div(phi,U) LUST grad(U); instead of > div(phi,U) Gauss linear;
If you have any knowledge to share on the effect of different numerical scheme, it would be amazing.
Kind regards,
Old   May 24, 2020, 13:38
Ardalan
That is a long story. LUST is a TVD scheme with conformal coefficient of 75% centeral differencing. If your case works with 'linear', I recommend to use it. Otherwise TVD with conformal coefficient of 0 is good too.
If you want to do DNS at moderately high Reynolds number, I recommend to put sometime to implement a higher order scheme. It helps you to have less expensive simulation.
Ardalan
Old   May 24, 2020, 18:47
Sereff
Hi again, I changed the numerical schemes, but it seems to be not helping.
I attached my plot of Rij (averaged from UPrime2Mean).
kind regards
Old   May 24, 2020, 18:51
Ardalan
Is it only the resolved part? Please add the modelled part and check again.
Old   May 24, 2020, 19:11
Sereff
yes... so the modeled Rij can be found by
> #includeFunc R;
and the target one is:
Rij = UMean2Prime + RMean?
or is it,
Rij = UMean2Prime + RMean2Prime?
Sorry for my stupid question...
Kind regards,
Old   May 24, 2020, 20:07
Ardalan
No, You have to take nutMean and calculate any term using Boussinesq.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
