Post-stall behaviour of airfoils using different turbulence models |
May 22, 2020, 10:18 |
Ashmita
Rep Power: 6 |
Hello everyone!
I am simulating a NACA0012 airfoil, from 0 to 180 degrees, and comparing the cl and cd results with NASA's experimental results. Up to stall, the Spalart-Allmaras model works just fine. However, I am unable to get converging results using the k-epsilon model even at low angles of attack even after 20k iterations. I have set the y-plus value to 30, my Reynolds number is 700k. I will be attaching my 0/ and system/ files. Can someone please take a look and tell me where I've gone wrong or what I'm missing? I have tried various things but I'm unable to set this right. I also want to know how to access the damping functions setting for the k-epsilon model in order to perform simulations for y-plus between 1&5. If someone can also direct me on any resource on how to use the k-omega and k-omega SST models for separated flow over airfoils, it would be very generous and would help me a lot. I'm new to CFD on OpenFOAM, and this is my first project. Thanks in advance! |
Utilities: post average turbulence fields and create turbulence fields for LES | Hanzo | OpenFOAM Running, Solving & CFD | 10 | August 18, 2017 19:33 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 15:18 |
Turbulence models become invalid at Re=2000~5000? | liweif | FLUENT | 9 | August 27, 2007 12:55 |
turbulence models? | haider | FLUENT | 0 | March 8, 2006 00:58 |
Turbulence Models and external flow. | Alan | FLUENT | 3 | November 22, 2005 05:46 |
