Parallelization of multi-region case
Old   May 22, 2020, 08:28
Default Parallelization of multi-region case
UebertreibeR is on a distinguished road
Hi Guys,
I'm running conjugate heat transfer simulations with chtMultiRegionFoam on OpenFOAM v6. Because some of my regions are very small (1e3 cells) compared to others (1e6 cells), I am thinking about using different levels of decomposition for each region.
Example:
Case with Regions 1 to 6 is decomposed in 8 subdomains. I want Region 5 to consist of only 2 subdomains instead of 8.
I tried using a different "numberOfSubdomains" for the region but while decomposePar runs fine, the solver complains about a missing "points"-File for region 5 in processors 2 - 7. They don't exist becuase, as defined, region 5 was only decomposed to processors 0 and 1.
What I'm trying to achieve seems to be possible in OF v1712 according to this link: https://www.openfoam.com/releases/op...2/parallel.php
Can anyone help me figure out if it can be done in OF v6 / v7 ?
Best wishes
UebertreibeR is offline   Reply With Quote
Error when solving p_rgh bob94 OpenFOAM 0 March 17, 2020 09:12
[OpenFOAM] Post Processing Multi Region .OpenFOAM malix38 ParaView 2 April 1, 2019 21:44
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Suggestions for a multi region conjugate heat transfer problem maddalena OpenFOAM 14 September 4, 2013 19:03
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 20:13
