May 19, 2020, 18:00 |
Are negative stresses tensile
Christopher Roper
Rep Power: 6 |
This seems fairly simple but due to my background, I am used to seeing negative stresses as compressive. However, when I am using solidDisplacementFoam I get a negative stress where I would expect a positive one. Does anyone know if the negative values for sigma in solidDisplacementFoam are tensile or compressive?
May 20, 2020, 12:51 |
Troy Snyder
Rep Power: 19 |
Negative values of stress indicate a state of tension in solidDisplacementFoam. In the attached figure, solidDisplacementFoam has been used to simulate the NAFEMS-10 validation case. You can look here...
https://www.sharcnet.ca/Software/Aba...mk/default.htm for the case setup in order to interpret the stress contour map. |
May 20, 2020, 15:46 |
Christopher Roper
Rep Power: 6 |
Thanks so much for your answer tas38. Do you know if there is a simple way to flip this data so that negative values are compression?
May 20, 2020, 16:07 |
Troy Snyder
Rep Power: 19 |
If it is just a matter of post-processing, the signs on the stresses can be changed within Paraview. You can use the 'calculator' filter and multiply the stresses by -1 (and create new/modified stresses) as needed.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
