overPimpleDyMFoam rotating airfoil startup problems
Old   May 19, 2020, 10:44
Default overPimpleDyMFoam rotating airfoil startup problems
Johannes N Theron
jantheron is on a distinguished road
Hi Foamers
I have set up an overset case on v1912 using the aeroFoil (incompressible-overSimpleFoam) tutorial as starting point.
My grid moves OK (I checked the geometry etc with moveDynamicMesh) and the holes are cut as they should.
However, when I start overPimpleDyMFoam, I get an error before the first time step:
Create mesh for time = 0
Selecting dynamicFvMesh dynamicOversetFvMesh
Selecting motion solver: multiSolidBodyMotionSolver
Applying solid body motion to entire mesh
Selecting solid-body motion function oscillatingRotatingMotion
Applying solid body motion oscillatingRotatingMotion to 138344 points of cellZone movingZone
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
Creating cellMask field to block out hole cells
Skipping suppressed overset interpolation for field cellMask
Creating interpolatedCells field
Skipping suppressed overset interpolation for field interpolatedCells
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod Poisson
Interpolating non-suppressed field grad(yPsi)
Interpolating non-suppressed field surfaceIntegrate(((1*magSf)*snGradCorr(yPsi)))
[0] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[6] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[7] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[1] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[2] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[4] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[3] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[5] dynamicOversetFvMesh::solve() : adjusting matrix for interpolation for field yPsi
[7] For field yPsi have zero diagonals for 0 cells
[4] For field yPsi have zero diagonals for 0 cells
[2] For field yPsi have zero diagonals for 0 cells
[3] For field yPsi have zero diagonals for 0 cells
[0] For field yPsi have zero diagonals for 0 cells
[6] For field yPsi have zero diagonals for 0 cells
[5] For field yPsi have zero diagonals for 0 cells
[1] For field yPsi have zero diagonals for 0 cells
[4] dynamicOversetFvMesh::solve() : writing matrix normalisation for field yPsi to yPsi_normalisation
[4]
[4]
[4] --> FOAM FATAL ERROR:
[4] Extended addressing not allocated
[4]
[4] From function const Foam::fvMeshPrimitiveLduAddressing& Foam::dynamicOversetFvMesh:rimitiveLduAddr() const
[4] in file dynamicOversetFvMesh/dynamicOversetFvMesh.C at line 584.
Can anyone shed light on this error?
Jan
Last edited by jantheron; May 19, 2020 at 11:00. Reason: Added more info on error code
jantheron is offline   Reply With Quote
Old   May 20, 2020, 05:55
Default WallDist
Johannes N Theron
It appears that when I switch to meshWave instead of Poisson for the wallDist calculation (fvSchemes), the problem goes away.
Has anyone come across this during overset calculations?
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
PROBLEMS WITH ROTATING FLOW BETWEEN TWO CYLINDERS vitmalin CFX 2 October 11, 2006 08:22
3d Airfoil Modelling Problems Olly FLUENT 7 March 19, 2006 16:10
More Rotating reference frame problems DaveG CFX 2 October 26, 2005 17:47
Rotating reference frame problems DaveG CFX 1 September 8, 2005 17:43
