MPPICFoam: Fatal Error while switching to RAS Models |
May 16, 2020, 12:29 |
vivek
Hello Everyone,
Hope everyone is safe and sound. I have an Error while trying to get myself accustomed with the usage of MPPICFoam. When i use injectionChannel tutorial as it is everything works fine. However when i tries switching to RAS model : kOmegaSST i get a fatal error FOAM FATAL ERROR: request for volVectorField U from objectRegistry region0 failed available objects of type volVectorField are 3(U.air U.air_0 cloudVolSUSu) The error occurs after the completion of first iteration of pimple solver. In my 0 folder i have the following files U.air, p, k.air, omega.air, nut.air Can somebody help me if i am missing some very trivial thing since i am pretty new in using MPPICFoam Thanks Vivek |
Numerical Problems with Non-Linear RAS models | cfdmarkus | OpenFOAM Running, Solving & CFD | 2 | November 12, 2018 18:08 |
why different models lead to different result for a same low-Re RAS case? | Sunxing | OpenFOAM | 0 | December 10, 2012 03:59 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 12:35 |
RAS Turbulence Models - Convective Term | john_w | OpenFOAM | 3 | May 29, 2010 22:31 |
wall functions for RAS models | Epf | OpenFOAM Pre-Processing | 3 | April 8, 2010 12:14 |
