odd results of kOmega SST and small yPlus
Old   May 15, 2020, 10:35
Unhappy odd results of kOmega SST and small yPlus
AmiN
AmiN.D is on a distinguished road
Hi Cfd-Online!
I'm a newbie in OpenFOAM world and happen to submit weekly projects since last month!
I' trying to simulate a very simple problem and geometry with kOmegaSST model in "simpleFoam" but the results are odd to me!
The geometry as you can see in attachment is a semi-orifice form and the fluid is water at 25ºC and gotta simulate it for Re=30 and Re=3000!
I dont use a fine mesh [Overall number of cells of each type :
hexahedra: 40000] .
With SST model i'm getting very small yPlus number for Re=3000 and Re=30
for example here are the results for Re=3000:
fixedWalls y+ : min: 0.000135994 max: 0.97708 average: 0.192186
and i assume it should be something between 5<y+<30
Both cases dont converge after 10000 interval which might be okay for Re=3000 but odd for Re=30, although after 8000 you dont see that much change in numbers.
what do you thing about y+ and also k,Omega, nut behavior ?
here are the conditions:
U:
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 -0.03);
outlet
type zeroGradient;
fixedWalls
type fixedValue;
value uniform (0 0 0);
fandb
type empty;
P:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
fixedWalls
type zeroGradient;
fandb
type empty;
Omega:
internalField uniform 0.3086;
boundaryField
inlet
type fixedValue;
value uniform 0.3086;
outlet
type zeroGradient;
fixedWalls
type omegaWallFunction;
fandb
type empty;
k:
internalField uniform 4.66e-06;
boundaryField
inlet
type fixedValue;
value uniform 4.66e-06;
outlet
type zeroGradient;
fixedWalls
type kqRWallFunction;
fandb
type empty;
nut:
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
fixedWalls
type nutkWallFunction;
value uniform 0;
fandb
type empty;
fvSolution:
solvers
p
solver GAMG;
tolerance 1e-08;
relTol 0.01;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
U
solver smoothSolver;
tolerance 1e-08;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-08;
relTol 0.1;
nSweeps 1;
epsilon
tolerance 1e-08;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-08;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-6;
U 1e-6;
potentialFlow
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
omega 0.7;
cache
grad(U);
thanks in advance
AmiN.D is offline   Reply With Quote
Old   May 16, 2020, 16:35
Klaus
klausb will become famous soon enough
check this to better understand what you're trying to do:
https://www.brighthubengineering.com...urbulent-flow/
Calculate the turbulence properties using e.g.:
https://www.cfd-online.com/Tools/turbulence.php
Dig a bit deeper into y+ ranges and mesh densities/properties suitable for your cases i.e. internal flow at your cases Re numbers.
Calculate y+ wall distance using e.g.:
https://www.cfd-online.com/Tools/yplus.php
And create a mesh that meets the y+ wall distance requirement for your case
Re = 3000 should be a turbulent case and kOmegaSST should work
Re = 30 should be a laminar flow case so maybe switch off turbulence in the constant/turbulenceProperties file
simulationType RAS;
RAS
    // Tested with kEpsilon, realizableKE, kOmega, kOmegaSST, v2f,
    // ShihQuadraticKE, LienCubicKE.
    RASModel        kOmegaSST;
    turbulence      on; // change this to off for laminar flow
    printCoeffs     on;
klausb is offline   Reply With Quote
bad heat transfer results with low y+ me45 OpenFOAM Running, Solving & CFD 0 April 29, 2020 12:56
RANS FX63-137 kOmega SST model PierluigiRossi SU2 2 June 24, 2016 06:56
which yplus (SST) sanchezz CFX 17 January 11, 2010 05:45
how to make grid for "SST" like small Re method? wayne CFX 0 June 7, 2008 12:09
Small Yplus and k-epsilon CFDworker CFX 3 November 4, 2005 00:08
