flux diverngence in simulating nasa rotor 67 using foam extend |
May 15, 2020, 05:08 |
hi
I hope you are well. I'm simulating nasa Rotor67 in foam-extend using steadyCompresibleMRF solver. after 7000 iteration , all of results converge to experimental design point , but max of flux divergence is still high and mach number is 0.1 higher than desgin point ( desgin point =1.38). 1- Is the flux diverngence important parameter to valdiate convergence? 2-how can I fix this parameter? 3- Do you have any idea to reduce the mach number ? Screenshot from 2020-05-15 03-59-37.jpg |
September 15, 2022, 12:17 |
Ji Ziqi
Hi, I am trying to simulate Rotor 67 in foam-extend, too. Can you help me about the boundary condition?
flux calculation, foam extend, foam-extend 4.1, mach number, rotor 67 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 11:35 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
