NACA 0012 Surface skin friction coefficient problem with kOmegaSST |
May 12, 2020, 16:52 |
Rep Power: 8 |
Hi everyone,
I've been facing a weird behavior in the Skin friction coefficient (Cf) of the NACA 0012 validation case from the OpenFOAM validation cases repertoire (https://www.openfoam.com/documentati...irfoil-2d.html ). Instead of using the SA model, I use kOmegaSST with a C-mesh created with blockMesh. I have run 3 cases with same number of elements, but changing the grading in the z direction to achieve different values of y+ (35, 7, and 5). While the 3 of them give me fair values of surface pressure coefficient (Cp graph attached), the Cf deviates more from the reference solution with lower values of y+ (Cf graph attached). I would have expected the solution close to the leading edge would get better by decreasing the y+ values. Is there anything obvious that could come to our mind by looking to the graphs and the mesh? I also attach the case files of one of the runs so you can check my setup. Best regards, Guillermo |
May 12, 2020, 17:46 |
Herpes Free Engineer
Rep Power: 13 |
- I think your results are pretty good within a typical engineering accuracy expectations. - Having said that, I think the predictions for this particular case is highly dependent on the wall functions/boundary conditions on wall for nut, and omega. - Would you try to use "nutLowReWallFunction" for nut, e.g. for the y1+ is within the viscous sublayer? - May be using fixedValue omega instead of omegaWallFunction may change things as well, but I am not sure if it would be stable enough. - Might help to tune the turbulence model coefficients to this specific case since kOmegaSST coefficients might be calibrated with other canonical flows. Have a go for a literature review if possible. Hope these help.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 14, 2020, 06:13 |
Rep Power: 8 |
Hi HPE,
Thanks for the reply. I have tried the following: 1. I used nutLowReWallFunction, but it yielded the same result as above. 2. I tried fixedValue for omega, but the solution diverges. What value should I impose at the wall for this case? Would it be necessary to change the fvSchemes according to the modifications? -Guillermo |
May 15, 2020, 18:12 |
Rep Power: 13 |
- I was suspecting that using `fixedValue` would cause numerical stability issues, and this happened. I think you can safely use `omegaWallFunction`, since for low-Re type meshes, there is no modelling - but resolving by using the analytical relations within the viscous sublayer. - For theoretical boundary conditions and their values being used in kOmegaSST, you can refer to the relevant NASA website. - Some of my previous comments do still apply. - Yet.. Could you please attach your `fvSchemes`, `fvOptions`? - Have you double checked the `nu` value - and are you sure that you are replicating the flow in terms of non-dimensional numbers, e.g. Re, given in the description? Hope this helps.
Producing Non-Zero Lift Coefficient for NACA 0012 at AOA=0 | cagesbuild | ANSYS | 1 | January 14, 2020 18:53 |
Fluent-Skin friction coefficient contours problem | ozturk | FLUENT | 1 | June 29, 2019 17:14 |
Skin friction coefficient over surface | mich_K | OpenFOAM Post-Processing | 14 | July 5, 2017 10:27 |
Mean skin friction coefficient | itoalberti | FLUENT | 0 | July 9, 2015 15:33 |
Skin friction coefficient | Anna Tian | CFX | 3 | January 28, 2013 10:25 |
