May 10, 2020, 11:47 |
Error with rhoCentralfoam
Jason.H
Rep Power: 8 |
Dear
I would like to solve supersonic flow for with rhoCentralfoam and Turbulence model is Spalart-Allmars model when I running the rhocentralFoam I get this error. I attached it I don't know what is the problem.... Can anyone help this? I'm not familar with openfoam |
May 11, 2020, 16:52 |
Floating Point Exception
Saikumar Reddy Y
Rep Power: 6 |
Error Floating point exception
You can check more about FPE over this thread, but it actually occurs with a illegal mathematical operation. You may have to look at your mesh and check for the problem. If doesnt work, try to play with tolerances. I would recommend rhoPimpleFoam, which is more stable, atleast in v7. Sometimes it can also occur with a wedge where the cells collapse. You can unset FOAM_SIGFPE if requires https://www.cfd-online.com/OpenFOAM_...tml?1201770596 |
May 13, 2020, 05:40 |
Jason.H
Rep Power: 8 |
Thank you for replying to me
I'm wodering what do you mean "toleranece"? Do you mean fvsolution? right? and Right now, to solve the problem I use laminar model to find out what is problem.. and also I have same error.... and I follow the instruction, I also get a same error message please help me.. |
How to apply a turbulence model to the rhoCentralFoam solver? | arussell92 | OpenFOAM Pre-Processing | 18 | July 25, 2022 05:26 |
Modify rhoCentralFoam: other equations of state | fivos | OpenFOAM Programming & Development | 5 | July 29, 2020 14:17 |
Inviscid simulation in rhoCentralFoam | chencw | OpenFOAM Running, Solving & CFD | 0 | April 13, 2018 16:49 |
dynamic mesh refinement and rhoCentralFoam | ChrisA | OpenFOAM Running, Solving & CFD | 1 | March 21, 2013 09:00 |
rhoCentralFoam solver with Slip BCs fails in Parallel Only | JLight | OpenFOAM Running, Solving & CFD | 2 | October 11, 2012 22:08 |
