May 5, 2020, 07:17 |
timeVaryingMappedFixedValue error
X
Rep Power: 7 |
Hi. I am working on a 2D axi case where I want to create a parabolic velocity profile at the inlet. I am trying to use the tutorial case pitzDailyExptInlet as a reference for the timeVaryingMappedFixedValue aspect.
My U file Code:
boundaryField { axis { type empty; } inlet { type timeVaryingMappedFixedValue; offset (0 0 0); setAverage off; } wall { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } front { type wedge; } back { type wedge; } } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) //0 (20 0 0) //1 (0 1 -0.04366094291) //2 (20 1 -0.04366094291) //3 (0 1 0.04366094291) //4 (20 1 0.04366094291) //5 ); blocks ( hex (0 1 3 2 0 1 5 4) (100 100 1) simpleGrading (1.0 1.0 1.0) //1 ); edges ( ); boundary ( axis { type empty; faces ( (0 1 1 0) ); } inlet { type patch; faces ( (0 0 4 2) ); } wall { type wall; faces ( (2 4 5 3) ); } outlet { type patch; faces ( (1 3 5 1) ); } front { type wedge; faces ( (0 1 5 4) ); } back { type wedge; faces ( (0 2 3 1) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
// Points 102 ( // min z (0.00 0.0000 -0.000000000000) (0.00 0.0020 -0.000087321886) (0.00 0.0040 -0.000174643772) (0.00 0.0060 -0.000261965657) (0.00 0.0080 -0.000349287543) (0.00 0.0100 -0.000436609429) (0.00 0.0120 -0.000523931315) (0.00 0.0140 -0.000611253201) (0.00 0.0160 -0.000698575087) (0.00 0.0180 -0.000785896972) (0.00 0.0200 -0.000873218858) (0.00 0.0220 -0.000960540744) (0.00 0.0240 -0.001047862630) (0.00 0.0260 -0.001135184516) (0.00 0.0280 -0.001222506401) (0.00 0.0300 -0.001309828287) (0.00 0.0320 -0.001397150173) (0.00 0.0340 -0.001484472059) (0.00 0.0360 -0.001571793945) (0.00 0.0380 -0.001659115831) (0.00 0.0400 -0.001746437716) (0.00 0.0420 -0.001833759602) (0.00 0.0440 -0.001921081488) (0.00 0.0460 -0.002008403374) (0.00 0.0480 -0.002095725260) (0.00 0.0500 -0.002183047145) (0.00 0.0520 -0.002270369031) (0.00 0.0540 -0.002357690917) (0.00 0.0560 -0.002445012803) (0.00 0.0580 -0.002532334689) (0.00 0.0600 -0.002619656575) (0.00 0.0620 -0.002706978460) (0.00 0.0640 -0.002794300346) (0.00 0.0660 -0.002881622232) (0.00 0.0680 -0.002968944118) (0.00 0.0700 -0.003056266004) (0.00 0.0720 -0.003143587889) (0.00 0.0740 -0.003230909775) (0.00 0.0760 -0.003318231661) (0.00 0.0780 -0.003405553547) (0.00 0.0800 -0.003492875433) (0.00 0.0820 -0.003580197318) (0.00 0.0840 -0.003667519204) (0.00 0.0860 -0.003754841090) (0.00 0.0880 -0.003842162976) (0.00 0.0900 -0.003929484862) (0.00 0.0920 -0.004016806748) (0.00 0.0940 -0.004104128633) (0.00 0.0960 -0.004191450519) (0.00 0.0980 -0.004278772405) (0.00 0.1000 -0.004366094291) // max z (0.00 0.0000 0.000000000000) (0.00 0.0020 0.000087321886) (0.00 0.0040 0.000174643772) (0.00 0.0060 0.000261965657) (0.00 0.0080 0.000349287543) (0.00 0.0100 0.000436609429) (0.00 0.0120 0.000523931315) (0.00 0.0140 0.000611253201) (0.00 0.0160 0.000698575087) (0.00 0.0180 0.000785896972) (0.00 0.0200 0.000873218858) (0.00 0.0220 0.000960540744) (0.00 0.0240 0.001047862630) (0.00 0.0260 0.001135184516) (0.00 0.0280 0.001222506401) (0.00 0.0300 0.001309828287) (0.00 0.0320 0.001397150173) (0.00 0.0340 0.001484472059) (0.00 0.0360 0.001571793945) (0.00 0.0380 0.001659115831) (0.00 0.0400 0.001746437716) (0.00 0.0420 0.001833759602) (0.00 0.0440 0.001921081488) (0.00 0.0460 0.002008403374) (0.00 0.0480 0.002095725260) (0.00 0.0500 0.002183047145) (0.00 0.0520 0.002270369031) (0.00 0.0540 0.002357690917) (0.00 0.0560 0.002445012803) (0.00 0.0580 0.002532334689) (0.00 0.0600 0.002619656575) (0.00 0.0620 0.002706978460) (0.00 0.0640 0.002794300346) (0.00 0.0660 0.002881622232) (0.00 0.0680 0.002968944118) (0.00 0.0700 0.003056266004) (0.00 0.0720 0.003143587889) (0.00 0.0740 0.003230909775) (0.00 0.0760 0.003318231661) (0.00 0.0780 0.003405553547) (0.00 0.0800 0.003492875433) (0.00 0.0820 0.003580197318) (0.00 0.0840 0.003667519204) (0.00 0.0860 0.003754841090) (0.00 0.0880 0.003842162976) (0.00 0.0900 0.003929484862) (0.00 0.0920 0.004016806748) (0.00 0.0940 0.004104128633) (0.00 0.0960 0.004191450519) (0.00 0.0980 0.004278772405) (0.00 0.1000 0.004366094291) ) // ************************************************************************* // Code:
// Data on points 102 ( //minz ( 1.0000 0.0000 0.0000) ( 0.9996 0.0000 0.0000) ( 0.9984 0.0000 0.0000) ( 0.9964 0.0000 0.0000) ( 0.9936 0.0000 0.0000) ( 0.9900 0.0000 0.0000) ( 0.9856 0.0000 0.0000) ( 0.9804 0.0000 0.0000) ( 0.9744 0.0000 0.0000) ( 0.9676 0.0000 0.0000) ( 0.9600 0.0000 0.0000) ( 0.9516 0.0000 0.0000) ( 0.9424 0.0000 0.0000) ( 0.9324 0.0000 0.0000) ( 0.9216 0.0000 0.0000) ( 0.9100 0.0000 0.0000) ( 0.8976 0.0000 0.0000) ( 0.8844 0.0000 0.0000) ( 0.8704 0.0000 0.0000) ( 0.8556 0.0000 0.0000) ( 0.8400 0.0000 0.0000) ( 0.8236 0.0000 0.0000) ( 0.8064 0.0000 0.0000) ( 0.7884 0.0000 0.0000) ( 0.7696 0.0000 0.0000) ( 0.7500 0.0000 0.0000) ( 0.7296 0.0000 0.0000) ( 0.7084 0.0000 0.0000) ( 0.6864 0.0000 0.0000) ( 0.6636 0.0000 0.0000) ( 0.6400 0.0000 0.0000) ( 0.6156 0.0000 0.0000) ( 0.5904 0.0000 0.0000) ( 0.5644 0.0000 0.0000) ( 0.5376 0.0000 0.0000) ( 0.5100 0.0000 0.0000) ( 0.4816 0.0000 0.0000) ( 0.4524 0.0000 0.0000) ( 0.4224 0.0000 0.0000) ( 0.3916 0.0000 0.0000) ( 0.3600 0.0000 0.0000) ( 0.3276 0.0000 0.0000) ( 0.2944 0.0000 0.0000) ( 0.2604 0.0000 0.0000) ( 0.2256 0.0000 0.0000) ( 0.1900 0.0000 0.0000) ( 0.1536 0.0000 0.0000) ( 0.1164 0.0000 0.0000) ( 0.0784 0.0000 0.0000) ( 0.0396 0.0000 0.0000) ( 0.0000 0.0000 0.0000) // maxz ( 1.0000 0.0000 0.0000) ( 0.9996 0.0000 0.0000) ( 0.9984 0.0000 0.0000) ( 0.9964 0.0000 0.0000) ( 0.9936 0.0000 0.0000) ( 0.9900 0.0000 0.0000) ( 0.9856 0.0000 0.0000) ( 0.9804 0.0000 0.0000) ( 0.9744 0.0000 0.0000) ( 0.9676 0.0000 0.0000) ( 0.9600 0.0000 0.0000) ( 0.9516 0.0000 0.0000) ( 0.9424 0.0000 0.0000) ( 0.9324 0.0000 0.0000) ( 0.9216 0.0000 0.0000) ( 0.9100 0.0000 0.0000) ( 0.8976 0.0000 0.0000) ( 0.8844 0.0000 0.0000) ( 0.8704 0.0000 0.0000) ( 0.8556 0.0000 0.0000) ( 0.8400 0.0000 0.0000) ( 0.8236 0.0000 0.0000) ( 0.8064 0.0000 0.0000) ( 0.7884 0.0000 0.0000) ( 0.7696 0.0000 0.0000) ( 0.7500 0.0000 0.0000) ( 0.7296 0.0000 0.0000) ( 0.7084 0.0000 0.0000) ( 0.6864 0.0000 0.0000) ( 0.6636 0.0000 0.0000) ( 0.6400 0.0000 0.0000) ( 0.6156 0.0000 0.0000) ( 0.5904 0.0000 0.0000) ( 0.5644 0.0000 0.0000) ( 0.5376 0.0000 0.0000) ( 0.5100 0.0000 0.0000) ( 0.4816 0.0000 0.0000) ( 0.4524 0.0000 0.0000) ( 0.4224 0.0000 0.0000) ( 0.3916 0.0000 0.0000) ( 0.3600 0.0000 0.0000) ( 0.3276 0.0000 0.0000) ( 0.2944 0.0000 0.0000) ( 0.2604 0.0000 0.0000) ( 0.2256 0.0000 0.0000) ( 0.1900 0.0000 0.0000) ( 0.1536 0.0000 0.0000) ( 0.1164 0.0000 0.0000) ( 0.0784 0.0000 0.0000) ( 0.0396 0.0000 0.0000) ( 0.0000 0.0000 0.0000) ) // ************************************************************************* // My blockMesh runs fine but when I run my solver, I am getting this error: Code:
Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading electricalProperties Reading field p_rgh Reading field U DTRIS2 - Fatal error! --> FOAM FATAL ERROR: Failed dtris2 with vertices:102 From function static Foam::triSurface Foam::triSurfaceTools::delaunay2D(const Foam::List<Foam::Vector2D<double> >&) in file triSurface/triSurfaceTools/triSurfaceTools.C at line 2568. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::triSurfaceTools::delaunay2D(Foam::List<Foam::Vector2D<double> > const&) at ??:? #3 Foam::pointToPointPlanarInterpolation::calcWeights(Foam::Field<Foam::Vector<double> > const&, Foam::Field<Foam::Vector<double> > const&) at ??:? #4 Foam::pointToPointPlanarInterpolation::pointToPointPlanarInterpolation(Foam::Field<Foam::Vector<double> > const&, Foam::Field<Foam::Vector<double> > const&, double, bool) at ??:? #5 Foam::PatchFunction1Types::MappedFile<Foam::Vector<double> >::checkTable(double) const at ??:? #6 Foam::PatchFunction1Types::MappedFile<Foam::Vector<double> >::value(double) const at ??:? #7 Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> >::updateCoeffs() at ??:? #8 Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> >::timeVaryingMappedFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #9 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #10 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #11 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #12 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:? #13 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:? #14 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&, bool) at ??:? #15 ? at ??:? #16 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #17 ? at ??:? Aborted |
September 8, 2020, 13:21 |
Hrishi
Hey mcfdma.
I am too facing the same problem, have you solve it ? |
September 8, 2020, 15:47 |
#3 | |
Petros Ampatzidis
Rep Power: 7 |
Welcome hk19,
I am quoting a possible solution to the problem: Quote:
Best, Petros |
timevaryingfixedmapped |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
