Uncertain k values with multiphaseStabilizedTurbulence
Old   April 27, 2020, 11:21
Default Uncertain k values with multiphaseStabilizedTurbulence
Grivalszki Péter
GrivalszkiP is on a distinguished road
Hi!
I have uncertain k values from my multiphase simulations.
I used the new multiphaseStabilizedTurbulence fvOption to get correct k everywhere. Unfortunatelly, I did not get the k values I expected. On my graphs, one can see average k in specified verticals. The green line shows the result I expect, but If I refine my mesh, the k values are not better, but worse. Why is it? Do I have to use different BCs, or is there a mistake in the fvOptions?
I have a RAS with k-omega SST turbulence closure, and I use kqRWallFunction on the walls. For free surface capturing, I use isoAdvector (interIsoFoam).
Thank you in advance!
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
    multiphaseStabilizedTurbulence1
        type            multiphaseStabilizedTurbulence;
        active          yes;
        multiphaseStabilizedTurbulenceCoeffs
            // Optional coefficients
            lambda2         0.1;   // A value of 0 sets the nut correction to 0
            Cmu             0.09;  // from k-epsilon model
            C               1.51;  // from k-omega model
            alpha           1.36;  // 1/Prt
GrivalszkiP is offline   Reply With Quote
Old   August 22, 2022, 00:58
Juwon Jang
djdudns is on a distinguished road
Hi what CFD problem it is?
djdudns is offline   Reply With Quote
interisofoam, isoadvector, kqrwallfunction, refinement, stabilizedturbulence
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
Velocity values are normal but pressure values are too big rv82 OpenFOAM Running, Solving & CFD 4 April 13, 2015 04:59
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
Plotting raw data values Wilesco Siemens 0 January 5, 2006 06:34
