Pressure driven compressible flow between two gas reservoirs
Old   April 23, 2020, 10:36
Default Pressure driven compressible flow between two gas reservoirs
dld
Michael
dld is on a distinguished road
i want to simulate the flow of helium between two gas reservoirs through a microscopic channel (d = 60 um).
On one side I pump in with a pressure of 100 bar, the other side is evacuated using a vacuum pump. Both sides are connected by a small channel (d = 60um, l = 2mm). I attached a sketch of the setup. For now I set the pressure in the low pressure region to 1 bar. In the end I'm interested in the pressure distribution and the mass flow rate.
I managed to achieve some results by using setFields. I set the pressures in the high pressure region to 100 bar and to 1 bar every else. Afterwards I could see how it evolved over time. (I copied the decompressionTank tutorial and used rhoPimpleFoam)
To save time, I just wanted to simulate the pressure driven flow in a circular pipe using rhoPimpleFoam.
I set the folliwng boundary conditions for p and U. I tried to estimate the flow velocity and set it as internalField.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0]; // Pascal
internalField   uniform 1e5;
boundaryField
    axis
        type            empty;
    inlet
        type            totalPressure;
        p0              uniform 1e7;
        value           $internalField;
    wall
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 1e5;
    front
        type            wedge;
    back
        type            wedge;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (800 0 0);
boundaryField
    axis
        type            empty;
    inlet
        type            zeroGradient;
    wall
        type            noSlip;
    outlet
        type            zeroGradient;
    front
        type            wedge;
    back
        type            wedge;
For helium I set the following thermophysicalProperties
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        nMoles          1;
        molWeight       4;
    thermodynamics
        Cp              5193.2;
        Hf              0;
    transport
        mu              1.96e-5;
        Pr              0.424;
I tried around a lot, but when I try to run the simulation I always get an error like this:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/usr/lib/libc.so.6"
#3  Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4  Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  ? in "/opt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
#7  ? in "/opt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
#8  ? in "/opt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
#9  ? in "/opt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
#10  __libc_start_main in "/usr/lib/libc.so.6"
#11  ? in "/opt/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
Floating point exception (core dumped)
I'm quite new to CFD simulation, could you give me some pointers in the right direction? I also attached the whole case directory.
dld is offline   Reply With Quote
Old   October 27, 2022, 15:45
Sakun
Sakun is on a distinguished road
i do have the exactly the same boundary conditions and error for my compressor blade simulation and did you able to find the solution ?
Sakun is offline   Reply With Quote
compressible flow, helium, pressure driven flow, rhopimplefoam
problem about pressure driven flow yhaomin2007 OpenFOAM Running, Solving & CFD 8 June 4, 2021 08:51
Pressure driven flow in 2D LES channelFoam sheaker OpenFOAM Running, Solving & CFD 0 June 26, 2017 15:44
Inlet and Outlet Pressure condition for Compressible Flow in FLUENT rsdsaurav FLUENT 1 May 17, 2015 15:19
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
