Thermophysical properties - multiple equations |
April 22, 2020, 17:08 |
Tobias Luiz Marchioro Toassi
Hello foamers,
I need to perform a convective-diffusive transient problem on the chtMultiRegionFoam, with air as fluid and concrete and carbon steel as solids. As a example, the specific heat of carbon steel is given by: from 20ºC to 600°C: Cp = 425 + 7.73e-01*T - 1.69e-03*T² + 2.22e-06*T³ from 600ºC to 735ºC: Cp = 666 + 13002/(738 - T) from 735ºC to 900ºC: Cp = 545 + 17820/(T - 731) from 900ºC to 1200ºC: Cp = 650 Cp is given in J/(kg*K). The other thermophysical properties of the carbon steel and concrete that I want to simulate are described on this master thesis, and I kindly encourage to see: http://hdl.handle.net/10198/19239, item nº. 4.1 (Is written in portuguese). How do I specify different equations to different temperature ranges in the thermophysicalProperties OpenFOAM file, as the example I give? Is that any other way to perform it? Thanks in advance. Last edited by tobias_toassi; April 22, 2020 at 19:34. Reason: Minor writing corrections. |
chtmultiregionfoam, openfoam, thermophysical parameters, thermophysicalproperties |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 15:30 |
chtMultiRegionFoam - Thermophysical Properties error | Tscar | OpenFOAM Running, Solving & CFD | 3 | September 23, 2021 12:34 |
[swak4Foam] Manipulate thermophysical properties with swak4foam? | TobM | OpenFOAM Community Contributions | 5 | January 5, 2016 03:29 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
conjugate heate transfer: thermophysical properties | skuznet | OpenFOAM Running, Solving & CFD | 0 | December 8, 2013 01:43 |
