Recommendation for pressure field?
Old   April 19, 2020, 21:41
Default Recommendation for pressure field?
felipe ortega
flowwwww is on a distinguished road
Hello everyone,
I am simulatin an oven. The oven has two ducts inside. One that inyect hot air and one that extract the air. The oven is open to the environment in its ends.
The boundary conditions al inlet and outlet are in the ducts. However, i dont know the pressure value there. The only known value is in the ends of the oven, where is open to the environment (Patm).
I cant obtain good values of the pressure distribution when i run the simulation. The only value across all the domain is the internal field value.
I would like to know if some of you have a recommendation for my boundary conditions in order to improve my results.
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    doorin
        type            fixedValue;
        value           uniform 1e5;
    doorout
        type            fixedValue;
        value           uniform 1e5;
    symmetry
        type             symmetryPlane;
    walls
        type            zeroGradient;
     box
        type            zeroGradient;
    inlet1
        type            zeroGradient;
    outlet1
        type            zeroGradient;
Best regards.
flowwwww is offline   Reply With Quote
boundary conditions, pressure field
External Magnetic Field Data Format for FLUENT MHD Module eduardvinter FLUENT 0 January 24, 2019 02:54
simpleDyMFoam on v1806 gamemakerh OpenFOAM Programming & Development 0 November 8, 2018 09:15
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 09:34
[General] How to create an additional vector with {Field 4, Field 5, Field 6} Bombacar ParaView 1 August 15, 2015 19:05
Demagnetization field jan0385 ANSYS 0 April 12, 2012 10:09
