April 16, 2020, 20:06 |
k-omega SST model problem
burak
Rep Power: 6 |
I'm new user of an OpenFoam. Actually, I have been working for 5 days on NACA0012 airfoil but I made little improvement about it. I have a question about this topic. My turbulence model has to be incompressible k-omega sst model but my NACA0012 model is just running with SpalartAllMaras .Otherwise , programme is giving error. Which initial/boundary conditions files should I choose ? As I said , Im so amateur now . Maybe its too basic question but i didnt find this answer. If you can help , I would be very grateful. Thanks |
April 16, 2020, 20:44 |
Troy Snyder
Rep Power: 19 |
The 0/ directory containing the boundary conditions must include k, omega, and nut files. You can look at the tutorials as to how to setup these files, i.e. typical wall functions, freestream conditions, etc.
April 17, 2020, 05:53 |
Herpes Free Engineer
Rep Power: 13 |
You might want to start with the links below.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
April 17, 2020, 06:27 |
Rep Power: 12 |
You have to find how to set up the k and omega boundary and initial conditions correctly.
Your boundary layer mesh is also important to choose the correct wall functions. There were some good kOmegaSST/OpenFOAM topics in this forum, you have to search and read them also... |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
Setting change from k omega to k omega SST | bingo641 | OpenFOAM Programming & Development | 0 | May 22, 2018 06:15 |
convergence problem of the SST and RNG k-e model for mixing tank | ziyan7 | FLUENT | 0 | March 8, 2011 07:13 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
