wallShearStress function object for single phase transport models only?
Old   April 10, 2020, 11:15
Question wallShearStress function object for single phase transport models only?
JM27 is on a distinguished road
I am running a two-phase simulation and I use the wallShearStress functionObject to plot the wall shear stress distribution on wall boundaries.
The flow is laminar and compressible, so my question is, does the wallShearStress functionObject in OpenFOAM work for my case or is it meant for single phase transport models only?
I've read elsewhere in this forum that the wallShearStress function yields incorrect results for multiphase flows.
The units of the WSS I obtain are in Pascal however they seem to be underestimated.
I'd be very grateful to anyone who shares their knowledge
JM27 is offline   Reply With Quote
Old   April 10, 2020, 14:32
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
wallShearStress can work for multiphase flows as well - is it possible to provide a MWE where it does not work properly?
HPE is offline   Reply With Quote
Old   April 14, 2020, 08:12
Hi HPE
Thanks for your reply
Unfortunately I cannot provide a MWE that proves this, however I have been trying to compare my results obtained using wallShearStress function object with existing results in literature. The maximum WSS due to jetting is expected to reach 100kPa but the maximum in my simulations is only a fraction of that
Do you know how I can calculate the wall shear stress in my simulations without using this function? It would be a good exercise to compare results using two alternative approaches.
Old   April 14, 2020, 09:13
HPE
HPE's Avatar
Don't know, sorry. But might be good to pay attention to the proper normalisation of the wallShearStress? May be that would be the problem? Otherwise, I don't think this FO has some type of bug.
Old   April 14, 2020, 10:15
Hi HPE,
I'm not sure I understand what you mean by proper normalisation of the wallShearStress - could you explain further, please?
Thanks!
compressible, laminar, multiphase, openfoam, wallshearstress
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[OpenFOAM.org] Instructions to install OpenFOAM-2.4.x on CentOS-6.10 redbullah OpenFOAM Installation 9 September 7, 2019 18:18
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
