libAcoustic for openFoam tutorial case (monopole-3D) |
April 8, 2020, 11:33 |
zein elserfy
Rep Power: 8 |
I was checking libAcoustic tool for using it for noise prediction and i run one of its tutorials (monopole-3D)
http://github.com/unicfdlab/libAcous...als/monopole3D I want to ask you some questions about the library for one of the tutorial cases (monopole-3D) 1- one of the variables in the fwhCommanSettings is dRef which is defined as domain wide for 2-D case, while in 3-D case it is set 1(monopole-3D)?and what does it mean? 2-Delay response time in fwhControl, why it is set to 10e-3 3-one of the functions include in controlDict is sphereAverage, i do not see any output files for that function?why is it added to controlDict 4-soundPressureSampling is used for creating firstly output Geometry format files in SurfaceGeometryData and then pressure sampling are created in pressureData in txt format,so how this text file is visualized 5-what is the aim of creating complexPressureData? |
March 14, 2021, 06:57 |
Guanjiang Chen
Rep Power: 6 |
Have you unterstanded this tutotrial? Some of my thinking is: 1.the dRef should be set as -1 for a 3D case how to use acoustic lib in openfoam 2.This depends on the distance between the noise source and control surface I think. 3.I delete this file, and it seems to have no influence on the results. 4.soundPressureSampling maybe is used for other sound prediction methods such as bem. The acoustic data is saved in acousticData. Regards, Guanjiang |
acoustics, libacoustics, monopole, openfoam |
MapFields doesnt work in the "counterFlowFlame2D" tutorial case | panachristos | OpenFOAM Running, Solving & CFD | 9 | August 26, 2018 21:27 |
bubbleFoam tutorial case with turbulence | setzberg | OpenFOAM Running, Solving & CFD | 6 | October 15, 2015 13:29 |
SRFSimpleFoam tutorial case blows up on laptop (but runs on desktop?) | AHMeng | OpenFOAM Running, Solving & CFD | 1 | April 27, 2012 08:34 |
case and dat file of FLUENT tutorial | Sajad Ranjbaran | FLUENT | 0 | November 8, 2006 06:55 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
