The alphaeqn in 2 phase incomprossible flow (driftFluxFoam) |
Elol
Rep Power: 6 ![]() |
Hello Foamers,
Right now , I am trying to develope my own incombressible multiphase slover starting from icoFoam solver. So, I bring the first step which I will add the alphaEqn form driftFLuxFoam to the solver (I use driftFluxFoam Solver as a refrence). However there is some questions regarding the solution method of the alphaEqn. the alphaEqn.H file solve this eqn ddt(alpha,t)+div(alpha, U) = 0 as follow: { word alphaScheme("div(phi,alpha)"); word alpharScheme("div(phirb,alpha)"); if (MULESCorr) { fvScalarMatrix alpha1Eqn ( fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1) + fv::gaussConvectionScheme<scalar> ( mesh, phi, upwind<scalar>(mesh, phi) ).fvmDiv(phi, alpha1) ); solve(alpha1Eqn); Info<< "Phase-1 volume fraction = " << alpha1.weightedAverage(mesh.Vsc()).value() << " Min(" << alpha1.name() << ") = " << min(alpha1).value() << " Max(" << alpha1.name() << ") = " << max(alpha1).value() << endl; tmp<surfaceScalarField> talphaPhiUD(alpha1Eqn.flux()); alphaPhi = talphaPhiUD(); if (alphaApplyPrevCorr && talphaPhiCorr0.valid()) { Info<< "Applying the previous iteration correction flux" << endl; MULES::correct ( geometricOneField(), alpha1, alphaPhi, talphaPhiCorr0.ref(), UniformField<scalar>(mixture.alphaMax()), zeroField() ); alphaPhi += talphaPhiCorr0(); } // Cache the upwind-flux talphaPhiCorr0 = talphaPhiUD; } for (int aCorr=0; aCorr<nAlphaCorr; aCorr++) { tmp<surfaceScalarField> talphaPhiUn ( fvc::flux ( phi, alpha1, alphaScheme ) + fvc::flux ( phir, alpha1, alpharScheme ) ); if (MULESCorr) { tmp<surfaceScalarField> talphaPhiCorr(talphaPhiUn() - alphaPhi); volScalarField alpha10("alpha10", alpha1); MULES::correct ( geometricOneField(), alpha1, talphaPhiUn(), talphaPhiCorr.ref(), UniformField<scalar>(mixture.alphaMax()), zeroField() ); // Under-relax the correction for all but the 1st corrector if (aCorr == 0) { alphaPhi += talphaPhiCorr(); } else { alpha1 = 0.5*alpha1 + 0.5*alpha10; alphaPhi += 0.5*talphaPhiCorr(); } } else { alphaPhi = talphaPhiUn; MULES::explicitSolve ( geometricOneField(), alpha1, phi, alphaPhi, UniformField<scalar>(mixture.alphaMax()), zeroField() ); } } if (alphaApplyPrevCorr && MULESCorr) { talphaPhiCorr0 = alphaPhi - talphaPhiCorr0; } alpha2 = 1.0 - alpha1; Info<< "Phase-1 volume fraction = " << alpha1.weightedAverage(mesh.Vsc()).value() << " Min(" << alpha1.name() << ") = " << min(alpha1).value() << " Max(" << alpha1.name() << ") = " << max(alpha1).value() << endl; } What I understand till this moment is that it starts to solve the equation using low order scheme to generate talphaPhiUD() in this section fvScalarMatrix alpha1Eqn ( fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1) + fv::gaussConvectionScheme<scalar> ( mesh, phi, upwind<scalar>(mesh, phi) ).fvmDiv(phi, alpha1) ); solve(alpha1Eqn); Info<< "Phase-1 volume fraction = " << alpha1.weightedAverage(mesh.Vsc()).value() << " Min(" << alpha1.name() << ") = " << min(alpha1).value() << " Max(" << alpha1.name() << ") = " << max(alpha1).value() << endl; tmp<surfaceScalarField> talphaPhiUD(alpha1Eqn.flux()); alphaPhi = talphaPhiUD(); then and *if condition* is applied to perform MULES if (alphaApplyPrevCorr && talphaPhiCorr0.valid()) { Info<< "Applying the previous iteration correction flux" << endl; MULES::correct ( geometricOneField(), alpha1, alphaPhi, talphaPhiCorr0.ref(), UniformField<scalar>(mixture.alphaMax()), zeroField() ); alphaPhi += talphaPhiCorr0(); } alphaApplyPrevCorr is an inlet from the user and here is my question : 1. why they apply MULES correction to the low order fluxes ? 2. what this condition (talphaPhiCorr0.valid()) mean ? Thank you guys in advance. |
MNM
Rep Power: 9 ![]() |
Hi Elol,
I'm also facing bit difficulty in understanding specific meaning of these terms clearly. Can you share if you found an answer or some resource where it is mentioned clearly. ![]() |
Elol
Hi MNM,
Sorry for the late answer, I don't know if you find the answer or not. After some research, I really advise you to take a look on the PhD thesis of Santiago Marquez Damian. It is entitled as " An Extended Mixture Model for the Simultaneous Treatment of Short and Long Scale Interfaces". He explained in chapter 2 the whole idea of weighting factors and how it is implemnted in openFoam. Enjoy reading it. It is really valuable work. Best regards Elol ![]() ![]() ![]() |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 08:38 |
CFX siphon two phase flow - boundary conditions | bolus13 | CFX | 18 | August 25, 2016 18:39 |
Two phase flow problem. | andyraq | Fluent Multiphase | 4 | August 21, 2016 21:57 |
gas-liquid 2 phase flow in microchannels using VoF | LyngHoo | FLUENT | 1 | November 13, 2012 19:01 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 16:48 |
