How to simulate a channel water flow with Saint-Venant equation
Old   April 7, 2020, 23:35
Post How to simulate a channel water flow with Saint-Venant equation
huahua is on a distinguished road
Hi everyone
I need to simulate a channel water flow in an inclined slope. Saint-Venant equations are mostly used to model surface flow. So I programmed a solver with Saint-Venant equation and Manning's equation.
The continuity equation was:
\frac{\partial h}{\partial t}+\frac{\partial u}{\partial x}+\frac{\partial v}{\partial y}+\frac{\partial w}{\partial z}=Qrain
The Manning–Strickler formula is used for relating velocity to friction slopes
u=\frac{h^{2/3}}{n_{man}}\sqrt{S_{x}}
v=\frac{h^{2/3}}{n_{man}} \sqrt{S_{y}}
w=\frac{h^{2/3}}{n_{man}} \sqrt{S_{z}}
Test case:
Rainfall continues for 30 min over a 183 m long parking lot (of Manning's
roughness 0.025) at an intensity of 1.4E-5 m/s, and then no rainfall for 30 min. The slope of the parking lot is 0.0016, just like the figure 1 shows.
The boundary of h(water depth) and U (velocity), are all set for zeroGradient.
I calculate the outflow rate at the end of the parking lot. Simulated water depth and outflow rate are increased for the first 30 min and then no change for the next 30 min, just like figure 2 shows.
However, compared with the analytical solution and other software's results, outflow rate are first increased and then reached steady status for the first 30 min rainfall time and then decreased for the next 30 min no rainfall time, just like figure 3 shows.
What could I do to change to adjust my results? the boundary condition for outflow? Or I should add the slope's elevation to the governing equation? Or the solver?
Can anyone please give me any advice?
Thank you very much for your attention!
huahua is offline   Reply With Quote
Free surface flow in 3D lectangular channel pygmi FLUENT 0 January 18, 2016 07:48
simulate a turbulent flow (Oil & Water) in a 3D pipe amin4547 FLUENT 0 June 7, 2015 06:29
Outlet BC for subcritical open channel water flow Ema40 Fluent Multiphase 0 April 18, 2015 05:57
Modeling of a channel flow with water and air Bazinga CFX 3 May 8, 2014 10:53
water channel flow with non symmetrical solution bruce OpenFOAM Running, Solving & CFD 1 October 21, 2011 13:00
