How to slow down the parcels?
Old   April 6, 2020, 13:16
Default How to slow down the parcels?
LT
NewKid is on a distinguished road
Hi, everyone, I am simulating a high injection pressure spray at different ambient pressures with sprayFoam solver. The case is running smoothly, but some predicted results do not agree with the experimental data very well. Therefore, I list some questions here and look for the possible answers or clues.
Questions #1: the parcels goes too fast after they come out of the nozzle exit, i.e. the penetration increases too fast. I have set the pressure at "uniform 2.0e6", the density is about 20kg/m^3, the predicted spray reaches the bottom of the domain (0.08m) at 0.001s while the experimental spray penetration is only 0.065m at 0.002s.
Question #2: if the parameter "parcelBasisType" in sprayCloudProperties is mass, how to config "flowRateProfile table"? Then what's the unit of "flowRateProfile table"?
Question #3: when the simulated fuel is decane(nC10H22), will OpenFoam give the properties itself or look for them in the therm.dat, if "defaultCoeffs" is yes?
Thanks in advance!
NewKid is offline   Reply With Quote
Old   April 6, 2020, 13:19
Default thermophysicalProperties file
LT
FoamFile
version 2.0;
format binary;
class dictionary;
location "constant";
object SprayCloudProperties;
solution
active true;
coupled true;
transient yes;
cellValueSourceCorrection on;
maxCo 0.3;
sourceTerms
schemes
rho explicit 1;
U explicit 1;
Yi explicit 1;
h explicit 1;
radiation explicit 1;
interpolationSchemes
rho cell;
U cellPoint;
thermo:mu cell;
T cell;
Cp cell;
kappa cell;
p cell;
integrationSchemes
U Euler;
T analytical;
constantProperties
T0 300;
// place holders for rho0 and Cp0
// - reset from liquid properties using T0
rho0 798.13;//1000;
Cp0 4187;
constantVolume false;
subModels
particleForces
sphereDrag;
injectionModels
model1
type coneNozzleInjection;
SOI 0;
massTotal 2.38e-5;//5.85e-6;//6.0e-6;
parcelBasisType mass;
injectionMethod disc;
flowType pressureDrivenVelocity;//flowRateAndDischarge;
Pinj 70e+6;
outerDiameter 0.15e-3;//1.9e-4;
innerDiameter 0;
duration 2e-3;
position (0 0 0);//(0 0.0995 0);
direction (0 0 -1);
parcelsPerSecond 40000000;
flowRateProfile table//unit is m^3/s
(0 1.49e-5)//(0 1)
(0.002 1.49e-5)//(0.002 1)
Cd constant 0.9;
thetaInner constant 0.0;
thetaOuter constant 18.0;//10.0;
sizeDistribution
type RosinRammler;
RosinRammlerDistribution
minValue 1e-06;
maxValue 0.00013;
d 0.00013;
n 3;
dispersionModel none;//stochasticDispersionRAS;//gradientDispersionRAS;//none;
patchInteractionModel standardWallInteraction;
heatTransferModel RanzMarshall;
compositionModel singlePhaseMixture;
phaseChangeModel liquidEvaporationBoil;
surfaceFilmModel none;
atomizationModel blobsSheetAtomization;//none;
breakupModel ReitzKHRT; // ReitzDiwakar;
stochasticCollisionModel trajectory;//none;
radiation off;
standardWallInteractionCoeffs
type rebound;
RanzMarshallCoeffs
BirdCorrection true;
singlePhaseMixtureCoeffs
phases
liquid
C10H22 1;
liquidEvaporationBoilCoeffs
enthalpyTransfer enthalpyDifference;
activeLiquids ( C10H22 );
ReitzDiwakarCoeffs
solveOscillationEq yes;
Cbag 6;
Cb 0.785;
Cstrip 0.5;
Cs 10;
ReitzKHRTCoeffs
B0 0.61;
B1 40;
Ctau 1;
CRT 0.1;
msLimit 0.2;
WeberLimit 6;
TABCoeffs
y0 0;
yDot0 0;
Cmu 10;
Comega 8;
WeCrit 12;
trajectoryCoeffs
cSpace 1;
cTime 0.3;
coalescence on;
blobsSheetAtomizationCoeffs
B 1.0;
angle 30.0;
cloudFunctions
Old   April 6, 2020, 13:20
Default p in 0 fold
LT
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 2e+06;
boundaryField
Outlet
type zeroGradient;
Walls
type zeroGradient;
Inlet
type zeroGradient;
Old   April 6, 2020, 13:25
Default Another point
LT
Another point is the parameters "massTotal" and "parcelsPerSecond", do they make the predicted penetration longer if I increase the former and decrease the latter? And how do they affect the computation?
parcels, penetration, sprayfoam
More parcels stuck than there have been in the system tomf OpenFOAM Running, Solving & CFD 1 April 30, 2019 07:11
The "pairCollision" in "kinematicCloudProperties" makes the computation extremly slow zhangxc0223 OpenFOAM Running, Solving & CFD 7 April 5, 2019 18:30
Fluent running increadibly slow MayTheFlowBeWithYou FLUENT 12 May 22, 2018 03:04
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
Unfinished particle tracks in simpleReactingParcelFoam Cornelia OpenFOAM Running, Solving & CFD 3 June 5, 2015 04:58
