Suction pressure distribution at the bottom caused by a ship propeller |
April 6, 2020, 06:41 |
LouisDS
Rep Power: 6 |
Dear OpenFOAM users,
I am doing research about the suction pressure distribution on the bottom caused by a ship propeller. These suction pressure are generated at the intake side of the propeller. The inlet velocity is chosen to be equal to zero. When I run my numerical model, the suction pressures are indeed generated, but I saw that far upstream of the propeller, the pressure is still negative instead of the zero Pressure value. I have added a screenshot which should clarify my problem. Intuitively, the pressure should assymptotically go the zero upstream of the propeller. Instead the pressure goes asymptotically to -4.99 Pa. This is a wrong result as far upstream, the bottom will not feel the presence of the propeller, so the pressure should be 0 here. Is there anyone who has experienced the same problem? I am thinking something is not right with my boundary conditions at the inlet. I tried multiple other ones, but I can't find a solution. Many thanks and kind regards, Louis |
actuator disc, boundary condition, pressure, propeller |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
Gas Diffusion and Pressure Distribution | Xuekun | Main CFD Forum | 0 | October 29, 2015 10:10 |
Pressure instabilities at the bottom of the domain | MaryBau | OpenFOAM | 6 | February 19, 2013 16:19 |
pressure distribution in water flow, differences in icoFoam and COMSOL | deniggo | OpenFOAM Running, Solving & CFD | 14 | September 30, 2010 03:48 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
