How to fill circular pipe with a fluid using setFields? Pipe is located at the center |
April 4, 2020, 07:34 |
Ahsan
Rep Power: 6 |
Dear FOAMers
I am simulating an underwater fountain with two different water densities. The fountain pipe is 30 cm in height and is located at the center of the tank. In order to fill the pipe with heavy water, I used a pipe with an inner diameter of 8 mm but an outer square cross-section of 16 mm X 16 mm so that I could fill it with the setFields by defining a box. Although in doing so, I went a bit away from our physical experimental conditions (since the actual pipe has 8 mm inside diameter and 10 mm outside diameter). I actually need a circular pipe, but the problem is that I don't know how to fill it with heavy water using setFields or any other technique. Kindly help me solve this issue. Much appreciation The screenshots of my domain are attached with this post. |
how to model the heat transfer of pipe located in the soil | reza67 | FLUENT | 5 | October 19, 2014 14:33 |
flow in circular pipe | Jackie | Main CFD Forum | 1 | February 18, 2003 12:58 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
