Issues with SimpleFoam negative number |
View Poll Results: What is your favorite color? | |||
Red |
0 | 0% |
Blue |
1 | 100.00% |
Green |
0 | 0% |
Yellow |
0 | 0% |
Pink |
0 | 0% |
Voters: 1. You may not vote on this poll |
Shelby
Rep Power: 6 ![]() |
Hi All!
I am struggling with getting my simulation to run completely through. I have refined the mesh, played with different fvSchemes and fvSolutions. I've also tried adding more faces to refine the mesh further in certain areas but wasn't very successful in running that simulation. I get this error: Courant Number mean: 2.88337e-05 max: 0.448034 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCGStab: Solving for Ux, Initial residual = 0.00375051, Final residual = 1.05253e-14, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.00375002, Final residual = 1.08457e-14, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.000551018, Final residual = 4.80447e-09, No Iterations 1 DILUPBiCGStab: Solving for e, Initial residual = 0.000639895, Final residual = 1.63491e-13, No Iterations 1 DILUPBiCGStab: Solving for p, Initial residual = 0.000234893, Final residual = 2.43724e-13, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.35978e-13, global = -5.8114e-14, cumulative = 0.000207546 PIMPLE: iteration 2 DILUPBiCGStab: Solving for Ux, Initial residual = 0.0060651, Final residual = 5.04781e-09, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.00362514, Final residual = 3.78705e-09, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.000523088, Final residual = 4.79466e-10, No Iterations 1 DILUPBiCGStab: Solving for e, Initial residual = 0.000871031, Final residual = 2.6713e-09, No Iterations 1 --> FOAM FATAL ERROR: Negative initial temperature T0: -5.55946 From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam: ![]() ![]() in file /home/pawan/OpenFOAM/OpenFOAM-v1912/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 56. FOAM aborting #0 Foam::error: ![]() addr2line failed #1 Foam::error::abort()sh: 1: addr2line: not found addr2line failed #2 Foam::species::thermo<Foam::hConstThermo<Foam: ![]() addr2line failed #3 Foam::hePsiThermo<Foam: ![]() ![]() ![]() addr2line failed #4 Foam::hePsiThermo<Foam: ![]() ![]() ![]() addr2line failed #5 ?sh: 1: addr2line: not found addr2line failed #6 __libc_start_mainsh: 1: addr2line: not found addr2line failed #7 ?sh: 1: addr2line: not found addr2line failed Aborted (core dumped) I'm not sure if I downloaded the STL files and if I should use binary rather than ASCII. Or maybe there is something still wrong with my mesh, but when I run checkMesh, it says OK. I attached my system file to view the blockMesh, and snappyHexMesh. I'm not sure what else to try. I put in an fvOptions with a temperature limit and running that now, but I'm trying to pinpoint what my other error might be. I appreciate any and all your help! |
Shelby
Hello Everyone,
I've updated my simulation a bit to try and run further through the motor, but I still end up getting a negative initial temperature error. I know this usually has something to do with the mesh. After running checkMesh -allTopography -allGeography, I find that I have some concave cells and faces. Those are the main errors and after reading through some other forums, I have found that those can mainly be ignored. Is there another way to check if your mesh is okay? Any advice or recommendations is greatly appreciated!! I'm still using sonicFoam and I'm just not sure which part is filled out incorrectly or why I can't get the simulation to finish. I've attached both my blockMesh dict and snappyHexMesh dict to see if I missed anything major. |
Shelby
Please anyone that can help me, I would greatly appreciate it.
All I can tell with the mesh is concavity. Could that be the only reason that causes the negative initial temperature? Any help or advice is greatly appreciated! |
checkmesh, openfoam, temperature error |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
