March 28, 2020, 01:51 |
Roughness and size of mesh close to surface
Mehdi Babamehdi
Rep Power: 15 |
I am using interFoam solver to simulate free surface water flow in a channel. The bottom of the channel has roughness, so I used nutkRoughWallFunction in boundary condition of nut for the surface. The height of the mesh close to surface is 5.0 mm. I investigate different Ks from 1.5e-4 to 3.0e-3. But the height of water is less than experimental data and the force acting on a bolder in the channel is higher than expected. But by increasing Ks these two parameter has been improved. Now my question is since Ks is 'sand-gran roughness height', if I increase Ks close to height of the cell, would it make the simulation wrong? i.e. how the height of cell and Ks correlated to each other?
If you need openFoam setup of the simulation, you can take a look at the repository in which I uploaded the case setup https://gitlab.com/Mehdi_Pejvak/free...master/setup_3 Last edited by mb.pejvak; March 28, 2020 at 01:55. Reason: Add gitlab repository address |
cell size, interfoam hull, openfaom-5, roughness sand grain |
[ANSYS Meshing] y* and surface roughness | acalado | ANSYS Meshing & Geometry | 0 | December 13, 2019 12:40 |
sediment scour_static friction coefficient and surface roughness | leang | FLOW-3D | 0 | November 8, 2018 05:32 |
[ANSYS Meshing] Meshing Micro Channel with surface Roughness | jonheb | ANSYS Meshing & Geometry | 3 | February 14, 2018 07:31 |
Surface Roughness Problem | hydr_eng1805 | FLOW-3D | 2 | December 15, 2014 09:29 |
Mesh size and equivalent sand grain rougthness | kordou | ANSYS Meshing & Geometry | 4 | February 15, 2011 07:16 |
