March 26, 2020, 03:16 |
OpenFoam parallel running
Hi, I am new to OpenFOAM and now runnig a two-phase flow case parallelly. But it doesn't work and returns the following errors. I am not sure where it is wrong and it seems the OpenMPI is not installed correctly?
The OpenFOAM-6 is what I use and OpenMPI-3.1.2 was installed before installing OpenFOAM on my Ubuntu. Thank you! ERROR: -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: ompi_rte_init failed --> Returned "(null)" (-43) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init_thread *** on a NULL communicator *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) [Lancelot-Ubuntu:8226] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed! ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. ------------------------------------------------------- |
June 3, 2020, 07:29 |
Rep Power: 8 |
can you post your commad lines?
how do you decompose your case? how do you start your solver for decomposed case? does the solver run without decomposition? |
parallel error |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
Running OpenFOAM in parallel in WSL with Ubuntu bash | FlyFox | OpenFOAM Running, Solving & CFD | 7 | March 17, 2020 11:08 |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 10:55 |
looking for instructions on using a cluster and running openFoam in parallel | a.Asadi | OpenFOAM Running, Solving & CFD | 3 | December 14, 2015 04:38 |
Running Error using Compressible OpenFoam Parallel mode | dhendria | OpenFOAM Running, Solving & CFD | 0 | February 13, 2014 21:53 |
