BC for pressure-pressure run in simpleFoam
Old   March 25, 2020, 02:23
Default BC for pressure-pressure run in simpleFoam
BastiL
bastil is on a distinguished road
Hello all,
I am trying to run a simpleFoam case with pressure inlet and pressure outlet. I know this is not be best way to do (but it runs in the commercial solvers I know). However, in this case I only have pressure BCs available. I tried following BCs:
Pressure: "totalPressure" for inlet patch, "fixedValue" for outlet pach -> looks reasonable
Velocity: "pressureNormalInletOutletVelocity" for both inlet and outlet patches. I want the solver to calculate velocity based on fluxes and pressure and make the direction normal to the patch faces. However, this gives me a velocity field of more or less zero everywhere in the domain and therefore zero mass flow as well. -> not reasonable
What are the correct/best BCs for the velocity field for this kind of BCs? Thanks.
bastil is offline   Reply With Quote
Old   March 25, 2020, 05:35
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
This is what I've used succesfully.
0/U
    inlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
0/p
    inlet
        type            totalPressure;
        p0              uniform 25.5426;
        value           uniform 25.5426;
    outlet
        type            fixedValue;
        value           uniform 0;
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 25, 2020, 08:29
BastiL
Thanks. This was one of my previous trys. Good news: Results where he same as for my last try. Bad news: Velocity results are not physical.
Old   March 25, 2020, 08:31
linnemann's Avatar
Niels Nielsen
Remember to use normalized pressure.
OF uses p/rho in in-compressible cases.
Linnemann
Old   March 25, 2020, 09:36
BastiL
I know, I did use normalized pressure. Volume flow is far from expected (e-10 instead of e-4). Indeed I did run the same case with velocity-inlet before and I know what pressure drop should give what volume-flow.
Old   March 26, 2020, 04:50
BastiL
Ok, I quick-checked with the "squaredBend" tutorial with OpenFOAM-v1906. The BCs given from linnemann above works as expected for this geometry.
I am currently investigating why it does not work as expected for my model.
Old   March 27, 2020, 04:51
Troy Snyder
tas38 is on a distinguished road
bastil,
I agree with the bc combination suggest by linnemann. For your particular case, is the dynamic pressure a significant fraction of the total pressure? If so, you may simply be setting the inflow total pressure too low.
tas38 is offline   Reply With Quote
Old   March 27, 2020, 05:57
BastiL
No it's not. However, my geometry is widely spreading over serveral arms and just merging together those arms at in- and outlet. Seems there is kind of numerical flutuation between the arms that make a solution impossilbe so far.
Suggestions on how to solve this are welcome.
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
simpleFoam - pressure (coefficient) of head shape GJM1991 OpenFOAM Running, Solving & CFD 4 May 12, 2015 18:15
[swak4Foam] Swak4Foam/GroovyBC for total pressure in simpleFoam fivos OpenFOAM Community Contributions 5 February 14, 2014 12:51
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
