Under-Relaxation factors for Simple Consistent method |
March 22, 2020, 14:23 |
Deutschland (DEU)
Rep Power: 6 |
Dear Foamers,
I am new to openFoam and am having troubling setting optimum under-relaxation factors for my case. My problem statement is as such: I want to simulate a reactor (see pic attached) with laminar incompressible flow, using SimpleFoam. The Reynold's number suggests that the flow within the reactor is well within 2000, hence is laminar through out the reactor. Problem: I am using the SimpleC algorith for my solver, and when I set the under-relaxation factors for the velocity to a high value such as 0.9 it leads to an oscillatory behaviour and the solution does not converge. I changed the under relaxation factor to a low value such as 0.001, and the solution converges, however I am unsure of the solution. I have tried a list of relaxation factors in between, and all exhibited a non-convergent behaviour. I need to know if I am going wrong somewhere with the low values for the under-relaxation factors. Could you guys please guide me on this? I have attached the fvSchemes, fvSolution files as well for reference. The dimensions mentioned in the jpeg image of the reactor are in mm. This is a bit urgent, since its a part of my master thesis, please help me out guys. Thank you for your time and consideration. Sincerely, Abhinav |
March 22, 2020, 17:59 |
#2 | |
MNM
Rep Power: 9 |
Well fvSchemes looks good, now coming to the relaxation factor, 0.001 is too much for sure. Go for something like
relaxationFactors { fields { p 0.3; } equations { U 0.7; } } Regarding this, Quote:
convertToMeters 0.001; |
March 22, 2020, 22:51 |
#3 | |
Deutschland (DEU)
Rep Power: 6 |
Thank you Shubam for your prompt reply. I have attached the checkMesh file for your reference. I have already tried with the orthogonal correctors and the higher relaxation factors as well. Nothing seems to work.
March 23, 2020, 06:01 |
MNM
Rep Power: 9 |
As you can clearly see your checkMesh has failed bcz of concave cells. For 2D geometry, it should not affect that much. But for your case, I'll suggest you to have a look at the 3rd post of the following link.
About OpenFOAM and concave faces or cells After this, u can import the case in paraView and can easily visualize the local cells where u need to perform further refinement to avoid their concave shape. |
Explicit Relaxation Factors | ebtedaei | FLUENT | 0 | February 20, 2018 13:48 |
Under relaxation factors | amjadfirst | FLUENT | 4 | October 6, 2016 22:28 |
A problem in applying Non-Stationary relaxation method (GMRES) | mb.pejvak | Main CFD Forum | 0 | February 4, 2014 22:57 |
Under Relaxation Factors | Abdul | CFX | 5 | October 21, 2008 03:16 |
relaxation factors and time accuracy | Mike | Main CFD Forum | 7 | May 21, 2005 13:41 |
