March 21, 2020, 17:56 |
MapFieds doesn't work
Rep Power: 6 |
Hi everyone,
I tried to use mapFields script but it doesn't work, showing me this error: interpolating alphat #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? at ??:? #4 ? at ??:? #5 ? at ??:? #6 ? at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Segmentation fault (core dumped) I also tried to use mapMethod option with mapNearest: the mapping worked but for some reason the simulation didn't start. I read this topic:mapFields major bug I tried to follow the solution proposed (change 10e-5 with 10e-10) but I wasn't able to do Allwmake.. Can everyone help me to fix this error? Thank you so much |
mapfields |
RP_Set_Integer does not work in parallel | 86lolo | Fluent UDF and Scheme Programming | 2 | July 3, 2014 11:37 |
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 04:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
