Getting unphysical Temperature with DynamicMesh
Old   March 17, 2020, 07:30
Default Getting unphysical Temperature with DynamicMesh
Eren
ErenC is on a distinguished road
Hello!
I have a case where I have to oscillate a wall in an enclosure(square cavity). Without oscillating wall everything is fine! When I use "reaaaally" low amplitude, it also works. But I also need relatively large amplitudes. Whatever I try (I tried multiple dynamicMesh options, displacementLaplacian for example) I can't get physical results. I get really low and high temperatures near oscillating wall that are lower and higher than boundary conditions, which is impossible!
Here are my files, and help would be great!
Thank you in advance,
Eren.
p boundary conditions are all zeroGradients.
U
boundaryField
    BAWall
        type            noSlip;
    BHWall
        type            noSlip;
    LWall
        type            movingWallVelocity;
        value           uniform (0 0 0);
    RWall
        type            noSlip;
    TWall
        type            noSlip;
    frontAndBack
        type            empty;
pointMotionUx
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       pointScalarField;
    object      pointMotionU;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    TWall
        type            uniformFixedValue;
        uniformValue    constant 0;
    LWall
       uniformValue    sine;
       frequency 10;
       amplitude 0.0001;
       scale     1;
       level     0;
    BHWall
    BAWall
    RWall
    cylinder
    backandBack
        type            empty;
dynamicMeshDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
motionSolver    velocityComponentLaplacian;
component       x;
diffusivity     directional (0 0 0);
// I ALSO TRIED DIFFERENT DIFFUSIVITIES BUT DIDNT WORK!
ErenC is offline   Reply With Quote
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 12:43
heat transfer coefficient value in floefd jason kid FloEFD, FloWorks & FloTHERM 10 October 16, 2016 17:55
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 02:42
How to get free stream temperature in boundary condition saharesobh FLUENT 0 October 9, 2012 18:12
Highly unexpected occurence of Enforce_bounds error Chander CFX 9 March 8, 2012 18:16
