March 10, 2020, 08:20 |
Foam fatal error
I ran the pisoFoam solver
This is the error I get and I don't know how to fix this 1]$ pisoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-73d878406f6b Exec : pisoFoam Date : Mar 08 2020 Time : 15:36:20 Host : "solon.cluster.intern" PID : 16436 I/O : uncollated Case : /home/acsj076/mesh2d.1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PISO: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Starting time loop forces forces: Not including porosity effects forces forceCoeffs: Not including porosity effects forceCoeffs forceCoeffs: Not including porosity effects Time = 0.01 Courant Number mean: 5.5125507e-07 max: 0.00041118421 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 5.7568872e-12, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.7022693e-10, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.098368273, No Iterations 8 time step continuity errors : sum local = 1.0845202e-07, global = -1.4203287e-08, cumulative = -1.4203287e-08 GAMG: Solving for p, Initial residual = 0.93957101, Final residual = 9.8172412e-07, No Iterations 151 time step continuity errors : sum local = 2.0235757e-08, global = -4.6316942e-11, cumulative = -1.4249604e-08 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::lduMatrix::residual(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char) const at ??:? #4 Foam::lduMatrix::residual(Foam::Field<double> const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) at ??:? #10 Foam::RASModels::kEpsilon<Foam::IncompressibleTurb ulenceModel<Foam::transportModel> >::correct() at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib64/libc.so.6" #13 ? at ??:? Floating point exception (core dumped) |
June 3, 2020, 07:08 |
Rep Power: 8 |
what did you try to simulate?
you should give more input on what you did try to do, otherwise one can't help, bc not all error messages are trivial. |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
