OpenFOAM v1912 Green Water Loading Case Implementation Problem |
March 11, 2020, 12:37 |
Semih Batuhan Candir
Rep Power: 6 |
Hello everyone,
I'm trying to implement the IHFoam Green Water Loading Case in OpenFOAM v1912, I have managed to create the mesh using damBreak case located in the multiphase interfoam ras tutorial, but now I am not able to solve the problem. When I try commands setFields or interFoam program exits with an error saying that "Cannot find patchField entry for rigthWall" I have checked every single parameter declaration in "0" file, but couldn't find where the problem is. If you could help me to solve the problem, I would be more than glad. Here is my blockMeshDict file; Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1.000; vertices ( (0.00 0.00 0.00) // 0 (2.39 0.00 0.00) // 1 (2.55 0.00 0.00) // 2 (3.22 0.00 0.00) // 3 (0.00 0.00 0.16) // 4 (2.39 0.00 0.16) // 5 (2.55 0.00 0.16) // 6 (3.22 0.00 0.16) // 7 (0.00 0.00 1.00) // 8 (2.39 0.00 1.00) // 9 (2.55 0.00 1.00) // 10 (3.22 0.00 1.00) // 11 (0.00 0.20 0.00) // 12 (2.39 0.20 0.00) // 13 (2.55 0.20 0.00) // 14 (3.22 0.20 0.00) // 15 (0.00 0.20 0.16) // 16 (2.39 0.20 0.16) // 17 (2.55 0.20 0.16) // 18 (3.22 0.20 0.16) // 19 (0.00 0.20 1.00) // 20 (2.39 0.20 1.00) // 21 (2.55 0.20 1.00) // 22 (3.22 0.20 1.00) // 23 (0.00 0.50 0.00) // 24 (2.39 0.50 0.00) // 25 (2.55 0.50 0.00) // 26 (3.22 0.50 0.00) // 27 (0.00 0.50 0.16) // 28 (2.39 0.50 0.16) // 29 (2.55 0.50 0.16) // 30 (3.22 0.50 0.16) // 31 (0.00 0.50 1.00) // 32 (2.39 0.50 1.00) // 33 (2.55 0.50 1.00) // 34 (3.22 0.50 1.00) // 35 ); blocks ( hex (0 1 13 12 4 5 17 16) (239 20 16) simpleGrading (1 1 1) hex (2 3 15 14 6 7 19 18) (67 20 16) simpleGrading (1 1 1) hex (4 5 17 16 8 9 21 20) (239 20 84) simpleGrading (1 1 1) hex (5 6 18 17 9 10 22 21) (16 20 84) simpleGrading (1 1 1) hex (6 7 19 18 10 11 23 22) (67 20 84) simpleGrading (1 1 1) hex (12 13 25 24 16 17 29 28) (239 30 16) simpleGrading (1 1 1) hex (13 14 26 25 17 18 30 29) (16 30 16) simpleGrading (1 1 1) hex (14 15 27 26 18 19 31 30) (67 30 16) simpleGrading (1 1 1) hex (16 17 29 28 20 21 33 32) (239 30 84) simpleGrading (1 1 1) hex (17 18 30 29 21 22 34 33) (16 30 84) simpleGrading (1 1 1) hex (18 19 31 30 22 23 35 34) (67 30 84) simpleGrading (1 1 1) ); edges ( ); boundary ( leftWall { type wall; faces ( (0 12 16 4) (4 16 20 8) (12 24 28 16) (16 28 32 20) ); } rigthWall { type wall; faces ( (7 19 15 3) (11 23 19 7) (19 31 27 15) (23 35 31 19) ); } lowerWall { type wall; faces ( (0 1 13 12) (1 5 17 13) (5 6 18 17) (2 14 18 6) (2 3 15 14) (12 13 25 24) (13 14 26 25) (14 15 27 26) (13 17 18 14) ); } sideWall { type wall; faces ( (24 25 29 28) (25 26 30 29) (26 27 31 30) (28 29 33 32) (29 30 34 33) (30 31 35 34) ); } symmetry { type symmetryPlane; faces ( (8 9 5 4) (4 5 1 0) (9 10 6 5) (10 11 7 6) (6 7 3 2) ); } atmosphere { type patch; faces ( (8 20 21 9) (9 21 22 10) (10 22 23 11) (20 32 33 21) (21 33 34 22) (22 34 35 23) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 0) (1.22 0.5 0.55); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { leftWall { type fixedFluxPressure; value uniform 0; } rightWall { type fixedFluxPressure; value uniform 0; } lowerWall { type fixedFluxPressure; value uniform 0; } sideWall { type fixedFluxPressure; value uniform 0; } atmosphere { type totalPressure; p0 uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { leftWall { type zeroGradient; } rightWall { type zeroGradient; } lowerWall { type zeroGradient; } sideWall { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // |
March 12, 2020, 03:17 |
Yann
Rep Power: 27 |
Hi Leuthar,
You just have a typo in your blockMeshDict : rigthWall instead of rightWall. This cause a mismatch between your patch names "rigthWall" in your mesh and your boundary condition defined for "rightWall". Cheers! Yann |
March 12, 2020, 16:42 |
Rep Power: 6 |
I was thinking the problem was in the boundary conditions, that would have take ages for me to find about that. Thanks a lot, very much appreciated!
green water loading, openfoam v1912 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
implementation of constant water levels as boundary conditions | horn | OpenFOAM Pre-Processing | 2 | October 12, 2015 17:45 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Can OpenFoam solve this problem? | salazardetroya | OpenFOAM Running, Solving & CFD | 1 | July 29, 2015 22:34 |
[Helyx OS] Problem Loading an existing OpenFoam case into HELYX | RocketMan1691 | OpenFOAM Community Contributions | 7 | March 5, 2013 17:39 |
