March 10, 2020, 10:13 |
pimpleFoam synthetic turbulence
Tom
Rep Power: 9 |
Hi All,
I'm interested in setting up an LES simulation with pimpleFoam for a spray nozzle.I want to introduce synthetic turbulence at the inlet. I saw that this has been done before with channel395 tutorial https://develop.openfoam.com/Develop...hannel395DFSEM https://www.openfoam.com/documentati...ity-dfsem.html The tutorial uses : Inlet patch Reynolds stress, velocity and turbulence length scale which have been extracted from DNS. I do not have access to DNS or experimental data. Would it still be possible for me to run the DFSEM? Additionally, in my converged simpleFoam solution for my BC i set up the inlet as totalPressure inlet and the outlet as fixedValue. Would it still be possible to use these conditions with the DFSEM? Tom |
March 16, 2020, 20:24 |
Hesam Tofighian
Rep Power: 7 |
I think you can estimate the value of Reynolds stress, velocity, and turbulence length scale at the inlet, but you need to consider a bit of inlet pipe. During the simulation, the inlet flow fields are resolved and modified in the pipe.
You can also use of mapped boundary condition, but in this case, You need a longer inlet pipe. It may also take a long time for the flow to be turbulence. |
How to apply turbulence suppression to a region? | seasoul | STAR-CCM+ | 1 | October 15, 2016 05:10 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 15:18 |
Displaying Turbulence Intensity in LES and creating a constant Turbulence Intensity | Anwer | FLUENT | 1 | August 8, 2016 17:59 |
Synthetic turbulence BC for LES | shahzeb irfan | Main CFD Forum | 0 | July 29, 2011 03:21 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 18:15 |
