Error while running code for binary alloy solidification
Old   March 10, 2020, 07:53
Question Error while running code for binary alloy solidification
d durga prasad
dp32 is on a distinguished road
Starting time loop
Courant Number mean: 0 max: 0
Time = 0.5
PIMPLE: iteration 1
DILUPBiCGStab: Solving for T, Initial residual = 1, Final residual = 9.11044e-09, No Iterations 33
DILUPBiCGStab: Solving for C, Initial residual = 0.00209571, Final residual = 4.70405e-10, No Iterations 1
THERMO: iteration 1 residual: 0
[0]
[0]
[0] [2]
[2]
[2] --> FOAM FATAL ERROR:
[2] incompatible dimensions for operation
[U[1 -2 -2 0 0 0 0] ] - [U[-1 6 0 0 0 0 0] ]
[2]
[2] From function [3]
[3]
[3] --> FOAM FATAL ERROR:
[3] incompatible dimensions for operation
[3]
[3] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = Foam::Vector<double>]
[3] in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvMatrix.C at line [1]
[1]
[1] --> FOAM FATAL ERROR:
[1] incompatible dimensions for operation
[1]
[1] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = Foam::Vector<double>]
[1] in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvMatrix.C at line --> FOAM FATAL ERROR:
[0] incompatible dimensions for operation
[0]
[0] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = Foam::Vector<double>]
[0] in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/finiteVolume/lnInclude/fvMatrix.C at line 1283.
[0]
FOAM parallel run aborting
I'm getting this error while running my code. could anyone please help me with this?
dp32 is offline   Reply With Quote
Old   March 11, 2020, 04:17
Default Inconsistent dimensions
Thomas Flint
tom_flint2012 is on a distinguished road
The error is because you are trying to subtract one field from another, and the units of the two fields are not the same.
See the openFOAM input and output guides for guidance. What equations are you solving? You May have missed a multiplicative factor that has dimensions that will make the fields compatible.
tom_flint2012 is offline   Reply With Quote
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 01:18
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 11:20
