Solving a surfaceScalarfield - how to implement boundary? |
March 9, 2020, 13:23 |
Rep Power: 8 |
Dear FOAMers,
I would like to solve an energy equation knowing all the respective values on the cells faces, like examplarily shown is this small piece of code: Code:
fvm::(rho, h) == fvc::div(kappaS * snGradT * faceArea) kappaS ... surfaceScalarField containing the thermal conductivity values snGradT ... surfaceScalarField containing the surface normal temperature gradients snGradT ... surfaceScalarField containing face Areas This code works fine for the internal field, e.g. with adiabatic boundaries and an internal heat source. Unfortunately, I'm not able to integrate the boundary conditions in an elegant way; until now I calculate and add an additional source term, whose calculation is different depending on the type of BC. Does anybody know if there is another way to integrate the values of the patch faces into the LES? Have a nice evening/morning/night/lunch, stockzahn |
March 11, 2020, 11:01 |
Rep Power: 8 |
Solved. The boundary fields have to be updated seperately. Problem was my lack of knowledge of the mesh structure in OF.
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
