Slow convergence in high Prandtl laminar cavity |
March 9, 2020, 08:31 |
Andrea Di Ronco
Rep Power: 9 |
Hello everyone!
I'm running some cases using a solver derived from buoyantBoussinesqSimpleFoam. The solver is intended for the simulation of liquid-fuelled nuclear reactors, such that basically I have some additional equations which end up calculating a "nuclear" volumetric energy source for the T equation. Such equations include a group of diffusive eigenvalue equations ("flux.*") and a group of scalar transport equations ("prec.*" and "dec.*"), which are all solved within the simple loop. Beside the said energy source and a volumetric heat sink of the form gamma*(T - Tref), the UTp equations are the same of the original solver. Nuclear equations are tightly coupled with fluid dynamics, due to some phenomena: 1) direct dependence of some nuclear properties on temperature (and on Boussinesq density); 2) dependence of the volumetric energy source on the transport due to convection and diffusion of some quantities ("prec.*" and "dec.*") I'm trying to reproduce a benchmark found in literature, in which the case is basically a laminar lid-driven 2D square cavity (sides are 2m long), with a lid velocity of 0.5 m/s. The properties adopted in the benchmark include: Re = 40 (based on lid length and velocity) Pr = 3.075e5 Sc = 2.0e8 The mesh is based on a 200x200 uniformly spaced grid (see attachment). Probably given such fluid properties, I'm experiencing quite low convergence rates. Does someone have some insight on how to improve the problem setting? Is there something stupid I'm doing with the case setup? Some info: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application msfrSimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 5000; deltaT 1; writeControl timeStep; writeInterval 100; purgeWrite 10; writeFormat ascii; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "p.*" { solver GAMG; smoother DIC; tolerance 1e-9; relTol 1e-2; maxIter 100; } "p.*Final" { $p_rgh; relTol 0; } "(U|k|epsilon|omega|R)" { solver GAMG; smoother GaussSeidel; tolerance 1e-9; relTol 1e-2; maxIter 100; } "(U|k|epsilon|omega|R)Final" { $U; relTol 0; } T { solver PBiCG; preconditioner DILU; tolerance 1e-15; relTol 1e-2; maxIter 100; } TFinal { $T; relTol 0; } "flux.*" { solver GAMG; smoother DIC; cacheAgglomeration true; nCellsInCoarsestLevel 50; agglomerator faceAreaPair; mergeLevels 1; tolerance 1e-15; relTol 1e-2; maxIter 10; } "flux.*Final" { $flux1; relTol 0; } "(prec.*|dec.*)" { solver GAMG; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 50; agglomerator faceAreaPair; mergeLevels 1; tolerance 1e-15; relTol 1e-2; maxIter 100; } "(prec.*|dec.*)Final" { $prec1; relTol 0; } } SIMPLE { nNonOrthogonalCorrectors 0; consistent yes; pRefCell 0; pRefValue 0; residualControl { "p.*" 1e-7; U 1e-7; T 1e-7; "(U|k|epsilon)" 1e-7; "flux.*" 1e-7; "(prec.*|dec.*)" 1e-7; } } relaxationFactors { fields { "p.*" 1; "flux.*" 0.7; } equations { T 0.7; "(U|k|epsilon)" 0.5; "(prec.*|dec.*)" 0.7; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default bounded Gauss linear; div(phi,prec1) bounded Gauss upwind; div(phi,prec2) bounded Gauss upwind; div(phi,prec3) bounded Gauss upwind; div(phi,prec4) bounded Gauss upwind; div(phi,prec5) bounded Gauss upwind; div(phi,prec6) bounded Gauss upwind; div(phi,prec7) bounded Gauss upwind; div(phi,prec8) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************************************* // |
buoyant boussinesq, high pr flows, laminar flow |
Temporal convergence of cavity problem | RAK | FLUENT | 1 | September 15, 2008 19:32 |
Slow convergence for Boundary Layer flow | Biga | Main CFD Forum | 2 | November 18, 2004 16:51 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Slow convergence | Jesper | CFX | 1 | July 7, 2004 16:59 |
High Prandtl Number Flow | yenk sitza | Main CFD Forum | 0 | April 22, 2003 17:41 |
