Why is pimpleFoam not stopping when desired residual is reached? |
March 8, 2020, 13:47 |
Axel
Rep Power: 10 |
I am trying to use the residual control feature of pimpleFoam. To do so I set my nOuterCorrectors to a large number (50) and added a residualControl dictionary to the PIMPLE dictionary. However for some reason pimpleFoam runs all 50 outer corrector loops instead of stopping earlier when reaching the residuals that are specified in residualControl Code:
PIMPLE: Iteration 49 smoothSolver: Solving for Ux, Initial residual = 1.7138e-09, Final residual = 1.7138e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1.23965e-10, Final residual = 1.23965e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 3.13221e-10, Final residual = 3.13221e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 2.92413e-07, Final residual = 2.11863e-09, No Iterations 4 time step continuity errors : sum local = 7.28902e-14, global = -1.81969e-14, cumulative = 7.11654e-08 GAMG: Solving for p, Initial residual = 2.05131e-07, Final residual = 2.05131e-07, No Iterations 0 time step continuity errors : sum local = 7.05742e-12, global = -4.9383e-14, cumulative = 7.11653e-08 PIMPLE: Iteration 50 smoothSolver: Solving for Ux, Initial residual = 2.20554e-09, Final residual = 2.20554e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1.588e-10, Final residual = 1.588e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 4.01691e-10, Final residual = 4.01691e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 0.897462, Final residual = 0.0052241, No Iterations 3 time step continuity errors : sum local = 1.35599e-07, global = -8.79393e-10, cumulative = 7.02859e-08 GAMG: Solving for p, Initial residual = 0.0628147, Final residual = 9.87277e-07, No Iterations 13 time step continuity errors : sum local = 2.82111e-12, global = -4.26893e-13, cumulative = 7.02855e-08 ExecutionTime = 7084.84 s ClockTime = 7196 s Courant Number mean: 0.0100155 max: 1.21183 deltaT = 0.002 Time = 0.078 Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { pcorrFinal { solver GAMG; tolerance 0.02; relTol 0; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration no; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } p { solver GAMG; tolerance 0; relTol 0.01; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration no; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } pFinal { $p; tolerance 1e-06; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } "(U|k|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0.1; } "(U|k|omega)Final" { $U; tolerance 1e-06; relTol 0; } cellDisplacement { solver GAMG; tolerance 1e-5; relTol 0; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } } PIMPLE { correctPhi no; nOuterCorrectors 50; nCorrectors 2; nNonOrthogonalCorrectors 0; residualControl { U 1e-5; p 1e-3; } } relaxationFactors { fields { p 0.3; pFinal 1.0; } equations { "(U|k|S|omega)" 0.7; "(U|k|S|omega)Final" 1.0; } } // ************************************************************************* // |
March 9, 2020, 00:56 |
Yogesh Bapat
Rep Power: 16 |
Pressure initial residual show large jump from 49 to 50th iteration. Is the trend same for previous iterations?
March 9, 2020, 12:01 |
Axel
Rep Power: 10 |
Hi ybapat,
thanks for your reply! I didn't even notice this. So if I look at a few loops then this jump seems only to appear in the last one. How can this be explained? Code:
PIMPLE: Iteration 41 smoothSolver: Solving for Ux, Initial residual = 4.09821e-09, Final residual = 4.09821e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 7.31785e-10, Final residual = 7.31785e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 7.09859e-10, Final residual = 7.09859e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 6.72052e-07, Final residual = 4.58509e-09, No Iterations 4 time step continuity errors : sum local = 1.18113e-13, global = -4.35361e-14, cumulative = 1.63738e-08 GAMG: Solving for p, Initial residual = 4.70794e-07, Final residual = 4.70794e-07, No Iterations 0 time step continuity errors : sum local = 1.21277e-11, global = -9.16023e-14, cumulative = 1.63737e-08 PIMPLE: Iteration 42 smoothSolver: Solving for Ux, Initial residual = 3.60249e-09, Final residual = 3.60249e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 6.5494e-10, Final residual = 6.5494e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 6.25585e-10, Final residual = 6.25585e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 6.08686e-07, Final residual = 4.15026e-09, No Iterations 4 time step continuity errors : sum local = 1.06911e-13, global = -3.89635e-14, cumulative = 1.63737e-08 GAMG: Solving for p, Initial residual = 4.26422e-07, Final residual = 4.26422e-07, No Iterations 0 time step continuity errors : sum local = 1.09847e-11, global = -8.39604e-14, cumulative = 1.63736e-08 PIMPLE: Iteration 43 smoothSolver: Solving for Ux, Initial residual = 3.17227e-09, Final residual = 3.17227e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 5.86625e-10, Final residual = 5.86625e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 5.51957e-10, Final residual = 5.51957e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 5.51378e-07, Final residual = 3.75597e-09, No Iterations 4 time step continuity errors : sum local = 9.67543e-14, global = -3.48606e-14, cumulative = 1.63735e-08 GAMG: Solving for p, Initial residual = 3.86293e-07, Final residual = 3.86293e-07, No Iterations 0 time step continuity errors : sum local = 9.95097e-12, global = -7.68566e-14, cumulative = 1.63735e-08 PIMPLE: Iteration 44 smoothSolver: Solving for Ux, Initial residual = 2.79689e-09, Final residual = 2.79689e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 5.25585e-10, Final residual = 5.25585e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 4.87377e-10, Final residual = 4.87377e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 4.99553e-07, Final residual = 3.39867e-09, No Iterations 4 time step continuity errors : sum local = 8.75501e-14, global = -3.11823e-14, cumulative = 1.63734e-08 GAMG: Solving for p, Initial residual = 3.49997e-07, Final residual = 3.49997e-07, No Iterations 0 time step continuity errors : sum local = 9.01596e-12, global = -7.0269e-14, cumulative = 1.63734e-08 PIMPLE: Iteration 45 smoothSolver: Solving for Ux, Initial residual = 2.46883e-09, Final residual = 2.46883e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 4.70952e-10, Final residual = 4.70952e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 4.30642e-10, Final residual = 4.30642e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 4.52814e-07, Final residual = 3.07493e-09, No Iterations 4 time step continuity errors : sum local = 7.92107e-14, global = -2.78865e-14, cumulative = 1.63733e-08 GAMG: Solving for p, Initial residual = 3.17251e-07, Final residual = 3.17251e-07, No Iterations 0 time step continuity errors : sum local = 8.17242e-12, global = -6.41737e-14, cumulative = 1.63733e-08 PIMPLE: Iteration 46 smoothSolver: Solving for Ux, Initial residual = 2.18214e-09, Final residual = 2.18214e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 4.22015e-10, Final residual = 4.22015e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 3.80768e-10, Final residual = 3.80768e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 4.10607e-07, Final residual = 2.7816e-09, No Iterations 4 time step continuity errors : sum local = 7.16544e-14, global = -2.49349e-14, cumulative = 1.63732e-08 GAMG: Solving for p, Initial residual = 2.8769e-07, Final residual = 2.8769e-07, No Iterations 0 time step continuity errors : sum local = 7.41093e-12, global = -5.85452e-14, cumulative = 1.63732e-08 PIMPLE: Iteration 47 smoothSolver: Solving for Ux, Initial residual = 1.93072e-09, Final residual = 1.93072e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.78169e-10, Final residual = 3.78169e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 3.36907e-10, Final residual = 3.36907e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 3.72391e-07, Final residual = 2.51584e-09, No Iterations 4 time step continuity errors : sum local = 6.48083e-14, global = -2.22925e-14, cumulative = 1.63732e-08 GAMG: Solving for p, Initial residual = 2.60925e-07, Final residual = 2.60925e-07, No Iterations 0 time step continuity errors : sum local = 6.72146e-12, global = -5.33575e-14, cumulative = 1.63731e-08 PIMPLE: Iteration 48 smoothSolver: Solving for Ux, Initial residual = 1.71012e-09, Final residual = 1.71012e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.38883e-10, Final residual = 3.38883e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 2.9831e-10, Final residual = 2.9831e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 3.37758e-07, Final residual = 2.27511e-09, No Iterations 4 time step continuity errors : sum local = 5.86071e-14, global = -1.99279e-14, cumulative = 1.63731e-08 GAMG: Solving for p, Initial residual = 2.3667e-07, Final residual = 2.3667e-07, No Iterations 0 time step continuity errors : sum local = 6.09664e-12, global = -4.85844e-14, cumulative = 1.6373e-08 PIMPLE: Iteration 49 smoothSolver: Solving for Ux, Initial residual = 1.5165e-09, Final residual = 1.5165e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.0368e-10, Final residual = 3.0368e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 2.64332e-10, Final residual = 2.64332e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 3.06366e-07, Final residual = 2.05708e-09, No Iterations 4 time step continuity errors : sum local = 5.29907e-14, global = -1.78126e-14, cumulative = 1.6373e-08 GAMG: Solving for p, Initial residual = 2.14683e-07, Final residual = 2.14683e-07, No Iterations 0 time step continuity errors : sum local = 5.53027e-12, global = -4.41998e-14, cumulative = 1.6373e-08 PIMPLE: Iteration 50 smoothSolver: Solving for Ux, Initial residual = 1.93382e-09, Final residual = 1.93382e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 3.89304e-10, Final residual = 3.89304e-10, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 3.35584e-10, Final residual = 3.35584e-10, No Iterations 0 GAMG: Solving for p, Initial residual = 0.930871, Final residual = 0.00720703, No Iterations 3 time step continuity errors : sum local = 1.38566e-07, global = -9.03646e-10, cumulative = 1.54693e-08 GAMG: Solving for p, Initial residual = 0.100811, Final residual = 7.13608e-07, No Iterations 14 time step continuity errors : sum local = 1.19524e-12, global = -1.76552e-13, cumulative = 1.54692e-08 ExecutionTime = 3426.79 s ClockTime = 3505 s Courant Number mean: 0.00563426 max: 0.984294 deltaT = 0.0013125 Time = 0.0134375 |
March 10, 2020, 00:11 |
Yogesh Bapat
Rep Power: 16 |
Noticed that you are changing URF to 1.0 for final iteration. I do not think it is required. Regarding convergence it is not clear why loop is not stopping before.
March 10, 2020, 04:03 |
Andrea Di Ronco
Rep Power: 9 |
Hi Axel!
May not be resolving and I'm still trying to figure it out, but I recently noticed that PIMPLE dictionary in fvSolution in recent OF releases also accepts a different keyword, outerCorrectorResidualControl. In OF6 you can find it used in the compressible/rhoPimpleFoam/RAS/angledDuct/ tutorial: Code:
PIMPLE { momentumPredictor yes; transonic no; nOuterCorrectors 50; nCorrectors 1; nNonOrthogonalCorrectors 0; consistent yes; simpleRho yes; pMaxFactor 1.5; pMinFactor 0.9; outerCorrectorResidualControl { "(U|k|epsilon)" { relTol 0; tolerance 0.0001; } } turbOnFinalIterOnly no; } Hope it helps! Andrea |
March 10, 2020, 10:50 |
Axel
Rep Power: 10 |
Hi Andrea,
yes, that solved the issue. Thank you! Using outerCorrectorResidualControl the loop is stopped as expected. Code:
PIMPLE: Iteration 23 smoothSolver: Solving for Ux, Initial residual = 1.82295e-05, Final residual = 8.33261e-14, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 6.45035e-06, Final residual = 6.45035e-06, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 3.31901e-06, Final residual = 3.31901e-06, No Iterations 0 GAMG: Solving for p, Initial residual = 1.83423e-06, Final residual = 1.22556e-08, No Iterations 4 time step continuity errors : sum local = 1.18399e-12, global = -2.94581e-13, cumulative = -5.23841e-09 GAMG: Solving for p, Initial residual = 1.28691e-06, Final residual = 1.29429e-07, No Iterations 1 time step continuity errors : sum local = 1.25039e-11, global = -1.27086e-12, cumulative = -5.23968e-09 PIMPLE: Iteration 24 smoothSolver: Solving for Ux, Initial residual = 1.44058e-05, Final residual = 6.32736e-14, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 4.70901e-06, Final residual = 4.70901e-06, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 2.63949e-06, Final residual = 2.63949e-06, No Iterations 0 GAMG: Solving for p, Initial residual = 1.275e-06, Final residual = 8.80647e-09, No Iterations 4 time step continuity errors : sum local = 8.50782e-13, global = -2.07543e-13, cumulative = -5.23989e-09 GAMG: Solving for p, Initial residual = 8.94593e-07, Final residual = 8.94593e-07, No Iterations 0 time step continuity errors : sum local = 8.64257e-11, global = -1.82023e-12, cumulative = -5.24171e-09 PIMPLE: Iteration 25 smoothSolver: Solving for Ux, Initial residual = 7.53999e-06, Final residual = 7.53999e-06, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 2.29805e-06, Final residual = 2.29805e-06, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 1.40777e-06, Final residual = 1.40777e-06, No Iterations 0 GAMG: Solving for p, Initial residual = 1.14894e-06, Final residual = 7.73808e-09, No Iterations 4 time step continuity errors : sum local = 7.47566e-13, global = -1.81834e-13, cumulative = -5.24189e-09 GAMG: Solving for p, Initial residual = 8.06083e-07, Final residual = 8.06083e-07, No Iterations 0 time step continuity errors : sum local = 7.78749e-11, global = -1.55066e-12, cumulative = -5.24344e-09 PIMPLE: Converged Doing final iteration PIMPLE: Iteration 26 smoothSolver: Solving for Ux, Initial residual = 7.21982e-06, Final residual = 5.87077e-14, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 2.06676e-06, Final residual = 2.38317e-15, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1.36745e-06, Final residual = 9.47398e-15, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00153052, Final residual = 1.2177e-05, No Iterations 3 time step continuity errors : sum local = 1.6783e-09, global = -1.30711e-11, cumulative = -5.25651e-09 GAMG: Solving for p, Initial residual = 1.71743e-05, Final residual = 9.55375e-07, No Iterations 3 time step continuity errors : sum local = 1.31499e-10, global = -1.6181e-11, cumulative = -5.27269e-09 PIMPLE: Converged in 26 iterations ExecutionTime = 57.25 s ClockTime = 58 s Courant Number mean: 6.00521e-05 max: 0.0158798 deltaT = 1.43712e-05 Time = 2.63616e-05 |
pimplefoam, residual control |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
