March 4, 2020, 07:15 |
Solving a curl equation (new to OpenFoam)
Manuel Ausserlechner
i am new to OpenFoam and i want to solve the equation: fvm::ddt(rho) = fvc::curl(vel x rho) *rho and vel are volVectorField's *i want to solve it with euler time steps in the loops *vel is always normal to rho (magnitude is constant =1) *initial conditions of rho should look like a circle, so i want to set the initialFieldValues with setFields i created a own solver by copying "scalarTransportFoam", what do i have to take care of to change my solver the right way? i would be so happy about some help LG aussm |
March 21, 2020, 15:09 |
MNM
Rep Power: 9 |
Hey Manuel, I assume that rho is not density here...
Well, Just use the createFields.H of scalarTransportFoam and declare both the volVectorFields similar to "U". And for the latter part where you want to solve for rho using fvm and fvc simultaneously at the same timestep... which is kind of difficult with the current syntax.....U should guide the solver to use the old values of rho in the fvc part.....So replace Code:
fvc::curl(vel ^ rho); Code:
fvc::curl(vel ^ rho.oldTime() ); |
curl, initial condition, setfields, vector field |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
