'value' of turbulentIntensityKineticEnergInlet type |
March 4, 2020, 04:12 |
Shin Gyu Sik
dear all, I'm analysising the flow from below into a jar-shaped flow field for medical device(pcr) with k-epsilon model.
I want to calculate the inlet boundary type of the k by set to 'turbulentIntensityKineticEnergInlet'. But I don't know what should I put in the 'value' field of 'turbulentIntensityKineticEnergInlet' type. To my knowledge, k can be calculated only by the turbulence intensity and velocity. Turbulence intensity is put from above and velocity is defined in U folder. Which 'value' is it for? Additionally, when calculating with a random value change, sometimes the calculation stops with a bounding k or epsilon error. But when I change the value, I get no error sometimes and convergence is good. How does 'value' affect this result? Thanks you for helping |
second order schemes | marine | OpenFOAM | 67 | April 11, 2022 19:19 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
rhoPimpleFoam hardship | petrus | OpenFOAM Running, Solving & CFD | 0 | October 7, 2016 03:41 |
interFoam/kOmegaSST tank filling with printStackError/Mules | simpomann | OpenFOAM Running, Solving & CFD | 3 | February 17, 2014 18:06 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 15:16 |
