Solver blow up due to negative psi values on several cells
Old   February 26, 2020, 11:28
Default Solver blow up due to negative psi values on several cells
Zeng
Soll is on a distinguished road
I'm currently using rhoCentralFoam to simulate a nozzle flow with body-force.
The solver blows up after several iterations. I did some research and found the problem occurs when the solver excutes
volScalarField c("c", sqrt(thermo.Cp()/thermo.Cv()*rPsi));
I write out the related field. It turns out that the rPsi field (1/Psi) has negative values (see attached fig), but the other part of the field is rather continuous.
Anyone has idea on this problem and how to debug? Any suggestions are appreciated.
Soll is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
"unknown psi type" error in reactingFoam Speno93 OpenFOAM Running, Solving & CFD 2 May 25, 2021 10:15
New solver errors, wmake Sedullo OpenFOAM Programming & Development 4 January 24, 2020 07:43
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
