February 25, 2020, 10:04 |
Parallel computation on a Ubuntu 18.04
Hello all,
I have a mesh thats of size 10 million elements. When i decompose it into 16 processors it works faster than for 24/32 or 48 processors. So I have decided to see if i can decompose this domain better or use 2 nodes in my workstation to reduce bandwidth and improve speed. Here is my workstation specs: Code:
Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 96 On-line CPU(s) list: 0-95 Thread(s) per core: 2 Core(s) per socket: 24 Socket(s): 2 NUMA node(s): 2 Vendor ID: AuthenticAMD CPU family: 23 Model: 49 Model name: AMD EPYC 7352 24-Core Processor Stepping: 0 CPU MHz: 3024.990 CPU max MHz: 2300.0000 CPU min MHz: 1500.0000 BogoMIPS: 4599.98 Virtualisation: AMD-V L1d cache: 32K L1i cache: 32K L2 cache: 512K L3 cache: 16384K NUMA node0 CPU(s): 0-23,48-71 NUMA node1 CPU(s): 24-47,72-95 Code:
demontfortuniversity-Super-Server.1 demontfortuniversity-Super-Server.2 demontfortuniversity-Super-Server.3 demontfortuniversity-Super-Server.4 demontfortuniversity-Super-Server.5 demontfortuniversity-Super-Server.6 demontfortuniversity-Super-Server.7 demontfortuniversity-Super-Server.8 demontfortuniversity-Super-Server.9 demontfortuniversity-Super-Server.10 demontfortuniversity-Super-Server.11 demontfortuniversity-Super-Server.12 demontfortuniversity-Super-Server.13 demontfortuniversity-Super-Server.14 demontfortuniversity-Super-Server.15 demontfortuniversity-Super-Server.16 localhost.1 localhost.2 localhost.3 localhost.4 localhost.5 localhost.6 localhost.7 localhost.8 localhost.9 localhost.10 localhost.11 localhost.12 localhost.13 localhost.14 localhost.15 localhost.16 When u run mpirun --hostfile hosts.txt -npernode 16 transientSimpleFoam -parallel >log " it fails to run giving me error message " There are not enough slots available in the system to satisfy the 0 slots that were requested by the application:" Couple of questions: 1) Is it possible for me to set up 2 nodes and 16 processors per node? What is the right command to do this? 2) Do I have to decompose the grid into node1 -> 16 proc and node2-> 16 proc ? or just a normal decomposition of say like simple "(8 2 2)" would be okay? 3) Would be it better if i install SLURM to do all this? |
Scaling of parallel computation? Solver/thread count combinations? | tdof | OpenFOAM | 8 | January 13, 2022 11:39 |
Parallel Build for SU2 on Ubuntu | McAero | SU2 | 11 | October 28, 2018 17:53 |
Any Procedure to setup parallel computation?? | fluidmechanics | SU2 Installation | 10 | July 21, 2017 04:31 |
Fluent parallel computation using Xeon duo-processor with CFD occupation below 50% | zhujj09 | FLUENT | 1 | October 19, 2016 15:02 |
Installation issues for parallel computation | Akash C | SU2 Installation | 1 | June 21, 2013 05:26 |
