February 25, 2020, 11:01 |
SimpleFoam Simulation blows up
ibrahim
Rep Power: 8 |
Hello Foamers,
I am trying to make a simulation of atmospheric wind flow over urban areas. I am using handmade blockmesh and my checkMesh evalutation is totally okay. Wind tunnel dimensions are 18,5*4*2 so model also has same dimensions. I am using atmospheric boundary conditions for inlet outlet and top which is named as atmos. For ground I am using atmospheric rough wall function. Ground is divided by 2. Incoming flow is face with higher roughness and housing part has nearly 0 roughness. I am attaching my all files to the post. My Question is, simulation is crashing. I am having so huge epsilon,k and time step continuity values and error says bad math happened. I tried to change my whole bc and ic condition and I refined mesh so many times but I couldn't find solution. I am waiting your precious ideas and helps U File Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (3.28 0 0); boundaryField { inlet { type atmBoundaryLayerInletVelocity; #include "include/ABLConditions" } outlet { type zeroGradient; // type inletOutlet; // inletValue uniform (0 0 0); // value uniform (6 0 0); } ground { type fixedValue; // type uniformFixedValue; // uniformValue constant (0 0 0); value uniform (0 0 0); } houses { type fixedValue; // type uniformFixedValue; // uniformValue constant (0 0 0); value uniform (0 0 0); } atmos { type atmBoundaryLayerInletVelocity; #include "include/ABLConditions" } #include "include/sideAtmos" } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 101000; boundaryField { inlet { type zeroGradient; value uniform 101000; } outlet { type fixedValue; meanValue uniform 101000; inletValue uniform 101000; value uniform 101000; } ground { type zeroGradient; } houses { type zeroGradient; } atmos { type zeroGradient; } #include "include/sideAtmos" } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.3; boundaryField { inlet { type atmBoundaryLayerInletK; #include "include/ABLConditions" } outlet { type zeroGradient; // type inletOutlet; // inletValue $internalField; // value $internalField; } ground { type kqRWallFunction; value uniform 0.0; } houses { type kqRWallFunction; value uniform 0.0; } atmos { type atmBoundaryLayerInletK; #include "include/ABLConditions" } #include "include/sideAtmos" } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; // type inletOutlet; // inletValue $internalField; // value $internalField; } ground { type nutkAtmRoughWallFunction; z0 uniform 0.0068; value $internalField; } houses { type nutkAtmRoughWallFunction; z0 uniform 0.00001; value $internalField; } atmos { type zeroGradient; } #include "include/sideAtmos" } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; //#include "include/initialConditions" internalField uniform 0.016; boundaryField { #include "include/sideAtmos" outlet { type inletOutlet; inletValue uniform 0.001; value uniform 0.001; } inlet { type atmBoundaryLayerInletEpsilon; #include "include/ABLConditions" } ground { type epsilonWallFunction; value uniform 0.0; } houses { type epsilonWallFunction; value uniform 0.0; } atmos { type atmBoundaryLayerInletEpsilon; #include "include/ABLConditions" } } Code:
Uref 3.28; Zref 0.6; zDir (0 0 1); flowDir (1 0 0); z0 uniform 0.0068; zGround uniform 0.000000001; value $internalField; Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; relTol 0.1; // tolerance 1e-7; smoother GaussSeidel; } "(U|k|epsilon)" { solver smoothSolver; smoother GaussSeidel; relTol 0.1; tolerance 1e-12; nSweeps 1; } } PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefPoint (0.00001 0.000001 300.00001); pRefValue 101000.0; hydrostaticInitialization yes; nHydrostaticCorrectors 5; } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } SIMPLE { nNonOrthogonalCorrectors 0; consistent no; residualControl { p 1e-4; U 1e-4; "(k|epsilon)" 1e-5; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; "(k|epsilon)" 0.7; } } Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; //Euler; } gradSchemes { default leastSquares; } divSchemes { default none; //div(phi,U) Gauss linear; // div(phi,k) Gauss linear; // div(phi,epsilon) Gauss linear; /* div(phi,U) Gauss fixedBlended 0.9 linear linearUpwind grad(U); div(phi,k) Gauss fixedBlended 0.9 linear linearUpwind grad(k); div(phi,epsilon) Gauss fixedBlended 0.9 linear linearUpwind grad(epsilon); */ // first oder upwind div(phi,U) Gauss upwind; // div(phi,k) Gauss upwind;// div(phi,epsilon) Gauss upwind;// /* // mixed div(phi,U) Gauss limitedLinear 0.01; div(phi,k) Gauss limitedLinear 0.01; */ div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { // default Gauss linear corrected; default Gauss linear limited corrected 0.5; } interpolationSchemes { default linear; } snGradSchemes { // default corrected; default limited corrected 0.5; // } fluxRequired { default no; p_rgh; } wallDist { method meshWave; //meshWave; Poisson; advectionDiffusion; } Error is in log file but to make it easier I am adding also here #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(F oam::dictionary const&) at ??:? #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? #9 ? in /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/simpleFoam #10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #11 ? in /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/simpleFoam Best Regards, Ibrahim |
February 28, 2020, 00:24 |
Svetlana Tkachenko
Rep Power: 15 |
Does it crash immediately or after some number of successful iterations?
What happens if you set the inlet velocity to zero? |
February 28, 2020, 08:10 |
ibrahim
Rep Power: 8 |
It crashes after 10 not succesfull iterations. I changed gradschemes from leastsquare to cell limited it is working but no converging.
If I set inlet velocity zero I dont think I will have huge gradients but I wont have correct result also. Best Regards, Ibrahim |
March 5, 2020, 19:45 |
Svetlana Tkachenko
Rep Power: 15 |
Perhaps simplify it to "flow around a rectangular block in a rectangular wind tunnel" while applying the same BCs, and if the issue still occurs, post the complete case here as an attachment.
Scalar field blows up (only) after restarting the simulation | backscatter | OpenFOAM Running, Solving & CFD | 3 | September 16, 2018 07:56 |
OF 4.1 + Helyx-OS v2.4.0 AMI Simulation blows up after 0.4 seconds | Ruonin | OpenFOAM Running, Solving & CFD | 4 | July 23, 2018 13:49 |
SimpleFoam - instable simulation | Specialist | OpenFOAM Running, Solving & CFD | 17 | August 12, 2014 05:52 |
Simulation of scrubber using simpleFOAM | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 5 | June 25, 2014 06:45 |
Cyclone Simulation (simpleFoam) | erncyc | OpenFOAM | 4 | January 28, 2011 10:40 |
