February 24, 2020, 12:46 |
Fatal Error using pimpleFoam
Rep Power: 6 |
Hello everyone! I am pretty new to OpenFoam.
I am trying to simulate a rotating rim using pimpleFoam. I am mainly trying to use the propeller tutorial case on my problem. I get the following weird error message in the pimpleFoam log file for all 4 Procs: Code:
1] --> FOAM FATAL ERROR: [1] [pcorr[1 -3 -1 0 0 0 0] ] == [div(phi)[0 0 -1 0 0 0 0] ] [1] [1] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::DimensionedField<Type, Foam::volMesh>&, const char*) [with Type = double] [1] in file /opt/OpenFoam-src/OpenFOAM-dev/src/finiteVolume/lnInclude/fvMatrix.C at line 1277. [1] FOAM parallel run aborting Does anyone know what the reason could be? Thanks! |
February 25, 2020, 05:10 |
Yogesh Bapat
Rep Power: 15 |
Check if you have provided dimensions of input fields correctly.
February 25, 2020, 07:13 |
Rep Power: 6 |
Thanks!
I thought my dimensions were correct but apparently you have to use [0 2 -2 0 0 0 0] for pressure when using pimpleFoam instead of [1 -1 -2 0 0 0 0] which is the normal unit for pressure. That confused me. |
February 26, 2020, 04:17 |
Yann
Rep Power: 27 |
Hi Lorg,
All incompressible solvers in OpenFOAM uses pressure normalised by density. This is why your pressure file has the dimension [0 2 -2 0 0 0 0]. https://openfoamwiki.net/index.php/O..._common_fields Cheers, Yann |
February 26, 2020, 06:01 |
Rep Power: 6 |
Ah cool, that makes sense. Thanks Yann!
pimpleFoam runs slower than rhoPimpleFoam | Kosuke Seto | OpenFOAM Running, Solving & CFD | 3 | May 27, 2023 14:12 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected | Djub | OpenFOAM Meshing & Mesh Conversion | 0 | July 15, 2014 04:43 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
