dsmcFoamPlus Read Point-Specified Inlet BC from File
Old   February 23, 2020, 11:59
Default dsmcFoamPlus Read Point-Specified Inlet BC from File
Andrew Weaver
Andrew W is on a distinguished road
Hey everyone,
I am using dsmcFoamPlus solver provided with OpenFOAM-2.4.0-MNF-1.0.1 package, and I am looking for an inlet boundary condition that reads point data from a file in a similar manner as timeVaryingMappedFixedValue. The intent is to be able to run a continuum solver, output data at a slice location where the flow becomes rarefied, and then read that data as inlet properties for the dsmcFoamPlus solver.
I have searched through this forum but was unable to find any documentation of this capability for dsmcFoam.
Does anyone have or know of this capability in any version of OpenFOAM? If not, I am also open to general advice on how to implement (I am new to OpenFOAM).
Thanks,
Andrew
Andrew W is offline   Reply With Quote
Old   June 29, 2020, 09:51
ano
ano
ano is on a distinguished road
In case it still helps someone:
dsmcFreeStreamInflowFieldPatch
You could map your slice data to the boundary of a field and use it as input.
Otherwise it is possible to use an arbitrary mesh interface.
ano is offline   Reply With Quote
Old   July 19, 2022, 11:56
Alexander Cushen
AlexanderCushen is on a distinguished road
If you want to initialise a dsmcFoam+ simulation with a specific (eg non-uniform) boundary condition, I wrote an explanation for how to do so here
Hope this helps!
AlexanderCushen is offline   Reply With Quote
boundary condition, dsmc openfoam dsmcfoam, dsmcfoam+, inlet flow profile
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
