Boundary condition for forced convection inside rotating cylinder
Old   February 20, 2020, 03:49
Default Boundary condition for forced convection inside rotating cylinder
saka
saka123 is on a distinguished road
Hi.
I am trying to simulate forced convection inside a rotating cylinder using pimpleFoam solver. Which boundary condition should I use for the 'U' file?
is 'rotatingWallVelocity' type is the correct one? For example:-
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
bottom
type rotatingWallVelocity;
origin (0 0 0);
axis (0 0 1);
omega 60;
top
type slip;
sides
origin (0 0 0);
axis (0 0 1);
omega 60;
The 'bottom', 'top', and 'sides' are the three sides of the cylinder.
Though it seems to simulate rotational flow inside, the solver is taking too much time to get the solution than for other cases with b.c. other than 'rotatingWallVelocity'.
Is this the correct way to simulate flow inside a rotating cylinder?
Suggestions are welcome.
saka123 is offline   Reply With Quote
Old   July 5, 2020, 17:05
sadsid is on a distinguished road
Originally Posted by saka123 View Post
Hi.
FoamFile
version 2.0;
format ascii;
object U;
boundaryField
bottom
origin (0 0 0);
axis (0 0 1);
omega 60;
top
type slip;
sides
origin (0 0 0);
axis (0 0 1);
omega 60;
Have you solve this issue? Got the desired results?
sadsid is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Symmetry/slip wall boundary condition in potential flow around a cylinder ilia.nikiforov Main CFD Forum 20 January 23, 2020 16:02
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
