Implicit discretization for nonlinear equations |
February 18, 2020, 13:04 |
Rep Power: 13 |
Hi all,
I am trying to solve a 2D PDE in time h = h(x,y,t) which is given here: This corresponds to basically a type of blistering film problem. I am able to implement a solver for this by modifying the scalarTransportFoam solver with the following HEqn: Code:
fvScalarMatrix HEqn ( fvm::ddt(H) -fvc::laplacian(Foam::pow(H,3.0),fvc::laplacian(fvc::laplacian(H))) == fvOptions(H) ); HEqn.relax(); fvOptions.constrain(HEqn); HEqn.solve(); fvOptions.correct(H); Thanks |
February 18, 2020, 13:38 |
Herpes Free Engineer
Rep Power: 13 |
fvm::laplacian instead of fvc::laplacian? Otherwise, adding as a source term, I suppose.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 18, 2020, 15:05 |
Rep Power: 13 |
Hi HPE,
Thanks, it seems like you cannot use fvm on any nested operations. For example, if you want the biharmonic operator, it seems like it will only compile as fvc::laplacian(fvc::laplacian(H)). It throws errors whenever I replace either of these fvc with fvm. Can you please expand on your suggestion to replace this as a source term? Basically implement the entire equation as a source term? dh/dt = F and then implement that as a calculated source term with fvOptions, or something like that? I'm not sure if that will solve the implicit vs. explicit calculation. Thanks again |
February 18, 2020, 15:16 |
Rep Power: 13 |
Can you construct the inner laplacian outside of fvMatrix, make the outer laplacian fvm::, and pass it as a vol?Field into the outer laplacian?
If H is a volScalarField, laplacian of laplacian of H will be again a volScalarField. But this new H will be H*, and will break down the fvMatrix. Hmm.. So the main problem is H* rather than the inner laplacian oper. Let me think further.
February 18, 2020, 15:19 |
Rep Power: 13 |
That term is currently a source term. Can you put it to rhs, with fvm::SuSp(your term), and test the stability again?
February 18, 2020, 15:26 |
Rep Power: 13 |
You may also want to implement your special laplacianLaplacian operator directly instead of executing laplacian twice, which would be expensive if you concern over the performance.
February 18, 2020, 15:44 |
Rep Power: 13 |
Hi HPE,
Thanks again for the advice. For fvm::SuSp, is that something that I can use directly in the modified solver? For example, if I had the biharmonic operator, would that be implemented as: fvm::SuSp(fvc::laplacian(fvc::laplacian(H)) I may be misunderstanding. For directly implementing something like laplacianLaplacian as a new operator, is that relatively straightforward? To be honest, I have never messed with working with these operators and I am not exactly sure where they are even implemented in OpenFOAM's directory structure. Thanks again. |
February 18, 2020, 16:03 |
Rep Power: 13 |
About the new operator: just leave it then. Your sims will be considerably fast enough.
So out of my head something like this: tmp<volScalarField> HStar ( fvc::laplacian ( pow3(H)*fvc::laplacian(fvc::laplacian(H)) ) ); In fvMatrix' rhs: fvm::SuSp(HStar/H, H); or tmp<volScalarField> HStar ( pow3(H)*fvc::laplacian(fvc::laplacian(H)) ); in fvMatrix's left hand side -fvm::laplacian(Hstar/H, H); Division and multiplication by H is an unfortunate trick, but it is being used in OpenFOAM anyways. So, I havent compiled them as I have been writing on the phone (as always), please let me know if it would be any help.
February 18, 2020, 16:15 |
#9 |
Rep Power: 13 |
Oh, and dont forget to bound H at the constructor stage as well as after fvMatrix to avoid the division by zero error:
bound(H, HMin); where you define HMin somewhere like: const dimensionedScalar HMin("HMin", H.dimensions(), SMALL);
February 18, 2020, 18:12 |
#10 |
Rep Power: 13 |
Hi HPE,
Thanks again, here is a quick update on your recommendations. Your first suggestion of : tmp<volScalarField> HStar ( fvc::laplacian ( pow3(H)*fvc::laplacian(fvc::laplacian(H)) ) ); In fvMatrix' rhs: fvm::SuSp(HStar/H, H); DOES compile, although it seems like it does not really offer any improvement to the stability. I'm not sure if it is still basically calculating everything explicitly and so failing for that reason or something more subtle. Your second suggestion of: tmp<volScalarField> HStar ( pow3(H)*fvc::laplacian(fvc::laplacian(H)) ); in fvMatrix's left hand side -fvm::laplacian(Hstar/H, H); does not actually compile for me. It gives me a "no matching function call error" for ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >::tmp(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)’ I'm not sure if you would have any other suggestions? In any case thanks a lot already. |
February 18, 2020, 22:50 |
#11 |
Rep Power: 13 |
Let me look at them when I sit in front of a PC, then, since I was always writing via my phone (always delaying good quality answers). The second option's problem is curious.
The first option should have helped, but may be the division causes a new issue. Which numerical scheme set do you use?
February 19, 2020, 08:23 |
#12 |
Rep Power: 13 |
Thanks, currently I have the solver setup like this:
tmp<volScalarField> HStar ( fvc::laplacian(Foam:ow(H,3.0),fvc::laplacian(fvc ::laplacian(H))) ); fvScalarMatrix HEqn ( fvm::ddt(H) - UnitCheck * fvm::SuSp(HStar/H, H) == fvOptions(H) ); And the schemes I am using are: ddtSchemes: backward gradSchemes: Gauss linear divSchemes: none laplacianSchemes: Gauss linear corrected interpolationSchemes: linear snGradSchemes: corrected |
February 19, 2020, 08:46 |
#13 |
Rep Power: 13 |
Also just FYI, it seems like the only schemes actually being used are ddtSchemes and laplacianSchemes, the rest I can all set to default none and everything runs.
February 19, 2020, 11:29 |
#14 | |
Lucky
Rep Power: 66 |
That is correct. Your equation has one ddt and one bilaplacian (which you are currently tinkering with in a laplacian approach). The other schemes are not needed and can be set to anything. You might need the in the future depending on how your implementation finally ends up working. |
February 20, 2020, 16:27 |
#15 |
Rep Power: 13 |
Does anyone have an idea of how I could implement an actual bilaplacian operator into openfoam so that I could directly use implicit calculation of that operator?
biharmonic, explicit, implicit, stability |
VOF Implicit formulation divergence issue | hamed.majeed | FLUENT | 0 | February 18, 2018 14:01 |
implicit crank nicolsol (burger equations) | drudox | Main CFD Forum | 13 | September 26, 2017 10:50 |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
SIMPLE Algorithm Finite Difference Equations: how to discretize and solve? | DA6righthand | Main CFD Forum | 0 | August 3, 2015 12:12 |
